Thread: Sorry - another display upgrade question
    Regular Member Chris B's Avatar
    Jan 2012
    Essex
    confused Sorry - another display upgrade question
    Chaps, I have a 2005 full canbus Vectra Estate with a bone standard clock / date / temp display.
    BUT - I have an aftermarket single din JVC headunit (bluetooth & ipod built in) fully fitted and working.
    Given that I don't have a GM headunit - not even the original one - can I still upgrade the display in anyway at all?
    Thanks Chris
    Jan 2012
    Essex
    Can anyone help me please?
    scottish region
    Think u would need to put in a paired vauxhall unit and screen in first then install the aftermarket mate
    Jan 2012
    Essex
    Quote Originally Posted by DAVIDD88 View Post
    Thanks David, yes I wondered if that might be the case - expensive just to get a little more info
    Shame
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Some of the challenge comes from turning on / off your info display warnings / pop-ups.
    If you have the steering wheel adapter kit for your JVC, then it is unlikely that you would be able to work the display.
    If you do not, then you have more ability to do so.
    Weirdly, it would be easier to fit a half-CAN upgraded display, and the wiper switch with fuel computer buttons on the end.
    gwent
    Yes you can still fit a new screen as you are using a after market head unit the screen does not have to be paired so no security that's what i've done but you still need to have it tech 2 to change settings
    Jan 2012
    Essex
    Thanks guys, so some hope then!
    Wayne I may PM you for some info if thats ok?
    Ta Chris
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by wayne10244 View Post
    You do need to bare in mind that many displays messages cannot be cleared without the head-unit buttons / knobs to press.
    Dependent upon set-up... especially full CAN (October 2004 onward) systems.
    Like I said above, half CAN is simpler with switches on the wiper stalk.
    You would need tech 2 for all BID, GID and CID displays, to set the clock and to change any BC settings etc.
    But you would not need the pass code to change these "Non-security" settings.
  1. Display upgrade, so what do I need?
    By Andyjarvis in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2012, 09:49
  2. Display upgrade...?
    By Ant SRi in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2011, 09:24
  3. Display upgrade
    By mbm_group in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2010, 15:44
  4. upgrade display unit
    By phillip in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2009, 21:55
  5. Display Upgrade ..can It Be Done
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd November 2006, 15:09
vectra c fuel display upgrade
