Thread: B0975 fault code
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    Default B0975 fault code
    Hello
    I took my clocks out to look at something but after plugging them back in the airbag light goes off then comes back on, I did not push the plug for the clocks back in properly before turning ignition on but did not realise at the time,
    Have read the code and get B0975 CSD Telltale Circuit Malfunction (Child Seat Detection)
    But resetting it made no difference as the code came back within seconds, how can I get rid of it.
    Regular Member simon7257's Avatar
    reading
    A telltale test using a diagnostic machine will just turn the warning light on, I'd take it all back out check the wiring and especially the pins inside the multiplug if you didn't fit it correctly it's possible to have bent one
    Oct 2010
    Walkden, Manchester
    Checked all pins this morning and all straight, is this a problem within the clocks as it only happened since I removed and replaced them.
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    could be the clocks, had this problem myself, new set of clocks cured it
    reading
    I've done a bit of looking around and I'm afraid I can't see a solution, your not the online to have had this problem but nobody has posted a fix, when you didn't fit the plug properly what didn't you do?
    Oct 2010
    Walkden, Manchester
    I will have to get a set of clocks off fleabay and hope for the best.
  1. B0975 fault code
    By Jonsey in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2012, 19:11
  2. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  3. fault code
    By mvl41183 in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2012, 22:26
  4. fault code help
    By delboy2028 in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 21:16
  5. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
