Thread: Help!!! CDTi oil filter
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Default Help!!! CDTi oil filter
    Hi everyone. I am in the middle of servicing a 1.9CDTi 150bps and the oil fliter is refusing to fit back into place. I have checked the length and internal diameter with the old one that came off and they are the same. Am doing something wrong or do I have to use a little force to get it back in place? Thanks
    You need to push the filter further in the housing mate - add the cover afterwards and it should screw in fine...
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    As above you need to push it in about an inch from where it sits at the moment
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Thanks to both of you for the replies. I eventually found the post by lee1828 http://www.vectra-c.com/forum/showthread.php?t=128683 which explained what I was doing wrong as I was fitting an aftermarket oil filter. All sorted out now. Thanks once again.
  1. 1.9 cdti air filter
    By richardcee in forum Diesel Engine related
    Last Post: 29th February 2012, 10:23
  2. K&N Air Filter - 150 CDTi
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2011, 06:55
  3. Oil Filter CDTi 150
    By Pete B in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2009, 21:49
  4. 3.0v6 cdti oil filter
    By nte01 in forum Engine & Drivetrain
    Last Post: 24th February 2009, 19:42
  5. cdti air filter
    By craigb in forum Diesel Engine related
    Last Post: 30th June 2008, 16:26
