Thread: tubrocharger wastegate
    exeter
    Default tubrocharger wastegate
    does anyone know if the tubrocharger wastegate solenoid should be making a ticking noise when the engine is running or idleing. about 2 or 3 times a secound
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    uplug it and and see it you can still hear it while idling.. the engine will still run but if you try to drive with it disconnected you will not get any boost.
    exeter
    if i take the pipe with the yellow ring off that goes to the wastegate i still get the ticking noise. but if i take the black one off its stops. but if i put my finger on it feel it sucking and the yellow side i cant feel anything . but i can see with the engine running and the yellow pipe connected i can see the wastegate arm moves away from the turbo and when i take it off i goes back to where it stays with the engine off
    exeter
    i also have a whinning noise on cold start ups if any body has any ideas please help . and help with should the wastegate solenoid be making a ticking noise
  1. Signum turbo wastegate help
    By redryan in forum Engine & Drivetrain
    Last Post: 18th February 2013, 21:46
  2. Chirping Wastegate...
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2011, 11:17
  3. Can you change a cdti to external wastegate?
    By swifty_53 in forum Diesel Engine related
    Last Post: 1st March 2011, 01:10
  4. possible wastegate actuator problems
    By Deztroyer in forum Petrol Engine related
    Last Post: 6th November 2009, 13:16
  5. 2.2Dti Wastegate...
    By Vectra-SRI in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2007, 19:29
