Thread: HIDs problem
    Regular Member Dazsri's Avatar
    North Wales, Towyn
    Vehicle : Vectra C Hatch
    Trim : Edition 100
    Engine : 2.0 Turbo Z20NET
    Mileage : 79000
    Default HIDs problem
    Hi people.
    I have bought a set of Supervision H7 HIDs for my vectra c (preface lift)
    I have connected them all up as the book shows and also has warning cancellers included in the box which are also fitted.
    The problem I'm getting is when the engine is running the light flickers and makes them look like strobes.
    Any1 have any ideas that can help?
    Regular Member Ben_'s Avatar
    Audiville, WM
    They flicker when they start up then get brighter as they warm up. Are yours strobing all the time?
    Double check connections are all tightly in might just be a bit loose.
    Audiville, WM
    North Wales, Towyn
    Trim : Edition 100
    Mileage : 79000
    Quote Originally Posted by Ben_ View Post
    When the engine is running the light switch off they have a flicker and if have them on turn engine off and lights off and ignition they ficker aswell.
    I removed all connections a reconnected incase of bad connection but same
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    You need to get Xenon mode enabled in the UEC with Tech 2, had the same issue myself. By switching on Xenon mode, it cons the car into thinking the factory Xenons are fitted and switches off the bulb check on the headlights. Take anyone with Tech2 about 2 mins to do.
    North Wales, Towyn
    Trim : Edition 100
    Mileage : 79000
    I've contacted HIDs direct as the kit is what they supply and hopefully then can point me in right direction.
    North Wales, Towyn
    Trim : Edition 100
    Mileage : 79000
    Just had email back from HIDs direct.
    They saying that I need another set of warning cancellers so that I have to double up the cancellers on each side and this should solve the problem.
    North Wales, Towyn
    Trim : Edition 100
    Mileage : 79000
    Regular Member chrisj88's Avatar
    Mar 2012
    newcastle
    hello mate,ive just put h.i.d's in my vectra and the same happened so i boughtg these off ebay and they work perfect now!!!http://www.ebay.co.uk/itm/2905166284...84.m1439.l2649
  1. Wiper Electrical Problem? (Not sticking or cold weather problem)
  2. HIDs bulb problem
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2012, 20:13
  3. Hids
    By dannyp in forum Introduce yourself.
    Last Post: 24th February 2011, 01:49
  4. HIDs
    By wangerdanger in forum General Chat
    Last Post: 8th March 2009, 15:36
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
