Thread: Uprated brake fluid-what should I use
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Uprated brake fluid-what should I use
    Hi all,
    I have gained a set of 345mm VXR brakes which I will be fitting over the coming weeks.
    So far I have ordered new HEL braided brake lines and pads from VX (using my GM discount) I thought it might be a good time to put in uprated brake fluid.
    The questions are, is is it a good idea to change to a better brake fluid and if so what should I get?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Go to 5.1 has a higher boiling point than standard dot 4
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Critch View Post
    thanks will get it sorted
    Wales
    You will never notice the difference on the road - brake fluid is brake fluid. As long as you are DOT 4 or above, you will be fine.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    You will if you push it hard enough.
    But then again you shouldn't be driving like that on a public highway.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Northampton
    Engine : A20DTH
    Mileage : 88000
    My thoughts were that I may as well use the best as I need to get some brake fluid anyways. Do not like to do things by half!
    Engine : 1.9 CDTi
    If you do go to 5.1 you will need to change it every year as its more hygroscopic than the normal stuff.
    Even on my trackday 16v Nova I only ever needed to use normal stuff.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by lee gsi View Post
    I think I will stick with standard then, every two years is enough for me
    Engine : 1.9 CDTi
    Just replacing it every 2 years will make a difference,
    Most people dont do it every 2 years anyway so once its done its so different.
  1. brake fluid
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2012, 01:09
  2. Dot 5.1 and Dot 4 Brake Fluid
    By smitd004 in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2011, 12:36
  3. uprated brake discs
    By hairy31 in forum Handling & Braking
    Last Post: 22nd January 2010, 23:55
  4. need to top up my brake fluid
    By The Gas Man in forum General Chat
    Last Post: 1st August 2009, 02:37
  5. Brake Fluid
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 23rd August 2008, 12:27
