Thread: Air Con Noise
    Regular Member CK1's Avatar
    Oct 2011
    Dublin
    Default Air Con Noise
    Can anybody offer any suggestions as to what is up with my A/C?
    It was re-gassed by an Opel Dealer in December and we never really use it. Anyway we had a wet day yesterday and the windows were misting up heavily so I turned the A/C on.
    There was a loud enough noise from it. Sounded like gas escaping from a pipe but the noise would stop a second after turning it off.
    Anybody ever had similar?
    Regular Member chrisdownes's Avatar
    West Midlands
    I had this last year with my car.
    It sounds like you've got a leak somewhere in the system.
    Suggest taking it to an Air-con centre so they can check it out.
    I had to have a new Condensor on mine, however it was done under warranty.
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    I have pm'd you
    Jul 2011
    edinburgh
    deffo the condenser - mine had the same noise - luckily for me it was replaced under warranty
    11 Post(s)
    Quote Originally Posted by CK1 View Post
    Well you should.
    AC is for all year round use.
    Plus it lubricates the rubber seals and helps prevent them from drying out and leaking gas.
    Oct 2011
    Dublin
    Well you should.
    I Know that now
    We came from a Mitsubishi Grandis 2.4 Auto Petrol so at times we used to drive in the dark with the lights off to save as much energy as possible
    We never used the A/C unless it was baking out. Never had a problem when we did in fact use it.
    Oct 2011
    Dublin
    The Vec went back to Joe Duffy Opel this morning and it's back now.
    They said it was caused by the incorrect amount of gas in the system which may heve been down to the equipment,
    Anyways regassed it free of charge and for now it is working perfect.
    Will keep an eye on it and use it regularly from now on.
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Yeah I would use it everyday ATM, just too see if it happens again. as it sounds like its been gassed and is working ATM, but may run out and do the same again indicating a hole in the rad.
    Oct 2011
    Dublin
    Yeah I said that to the Service Manager and he said he would check it.
    He then said everything was fine but that they had had an equipment issue previously resulting in the wrong amount of gas being given?
    Anyways it was FOC today so they must feel responsible?
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Yeah, could be ok now but just keep an eye mine was well and truest destroyed when I had mine gassed before changing the condenser, it held the gas for a whole 40mins so the guy at the garage reckoned lol
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. noise
    By leighhockey in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2012, 01:31
  3. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  4. noise
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2010, 22:37
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
