Thread: instrument light fuse ?
    Regular Member neilb1's Avatar
    Feb 2011
    wigan
    Default instrument light fuse ?
    Anyone know the fuse for the instrument lighting all the clock lightening is out and not working rev, speedo and petrol gauge
    vectra c as well
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Sounds more like a faulty CIM..
    PRESTON
    It does sound like a faulty cim, but check fuse 12 in dash fusebox.
    Feb 2011
    wigan
    whats a cim ?
    PRESTON
    It's the control unit on the steering column that controls dash lights, speedo, rev counter and fuel/temp gauges.
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Could also be the dash clock assembly itself, mine went that way, cim is fine...
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Or even the ABS plug if your cars in the right age group and a 54 plate fits it perfectly, mind you so does a faulty CIM Check THIS out mate.
    May 2006
    North Wales
    I think mine has the same symptons - when I put key in only engine light onfar right is light. Engine starts and the light goes out. |Then no lights on dashboard and no speedo, fuel revs etc. Indicators and lights work ok. Has your problem been solved with a fuse (hoping!).
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Quote Originally Posted by Mike57 View Post
    Exactly the same symptoms as mine, search for a thread called "dashboard is kapput"
    Mine wasn't the cim or any fuses, just the dash irself that had died....
    May 2006
    North Wales
    Found a useful thread with helpful fuse numbers from Robsey. I removed and put back fuses 17, 26 and 10 from the passenger side fusebox, and all is well!! I am not sure which one did the trick, but it saved me an expensive trip tto the dealers. I hope this will solve your problerm as well, neilb1. For info, my clock/temp was working, and pulling out 1 of the three fuses above reset the clock.
  1. What fuse for interion light?
    By amd in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2011, 00:00
  2. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
  3. B1454 (AFL) and B2652 (Instrument light)
    By fikse in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2011, 12:13
  4. Parkpilot Instrument Light, Tech 2 help needed
    By tramman in forum Electrical & ICE (including SatNav)
    Last Post: 7th April 2010, 20:35
  5. Boot light - Where is the fuse?
    By Schui1024 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2010, 01:04
