Thread: Headlights Issue
    Feb 2011
    London
    Default Headlights Issue
    Hi All,
    The other day I got a warning up on the dash saying that one of my dipped beam bulbs had failed. Upon inspection, this was correct.
    (Car is a 2004 SRI T 100)
    I took the rubber protector off and was trying to remove the bulb when it mysteriously came back on! The light worked fine until I pulled up at home and when I turned the car on and off a couple of times to check the light, it was working correctly.
    Next morining and the light fails again. A quick fiddle with the wring directly behind the bulb and the light pops on again.
    I assume this is a wiring issue, has anyone else had problems the same s this?
    I've also had issues with the car telling me that the side light is out when it isn't on the same headlight assembly.
    Any ideas as to where to look first? MOT is due in a couple of weeks!
    Matt
    11 Post(s)
    Sounds like the connections could do with a clean up.
    As most are a spade connector you can also tighten them up a bit with pliers to make them pinch tighter on the spade terminal they're being pushed on to.
    Regular Member lutonmatt's Avatar
    Feb 2012
    kent
    will be the bulb the wire inside has broke and everytime you touch it its connects and most of the time will stay that way till you turn the lights off
    Feb 2011
    London
    New bulb it is then for starters!
    Any ideas on the side light?
    Feb 2011
    London
    The new bulb has cured it and I'm yet to see the sidelight warning come back.
  1. Odd hid issue
    By aerodynamic18 in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 23:16
  2. Is this really the issue? Will a new EGR fix it?
    By DAS2 in forum Engine & Drivetrain
    Last Post: 16th September 2010, 08:26
  3. Possible air con issue
    By bigknill in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2010, 01:15
  4. Another DPF Issue
    By mushy2007 in forum Engine & Drivetrain
    Last Post: 22nd December 2007, 11:26
  5. Xenon Headlights Auto Levelling Issue
    By bigstevex in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2007, 21:14
