Thread: help 2.2 direct fuel smell in cabin
    Aug 2010
    shropshire
    Default help 2.2 direct fuel smell in cabin
    can any one help, my sri 2.2 direct 2006 has started to send fuel vapur smell into the car there is no spanner light or anything she runs sweet (no missfiring)
    the only difference i have made was to put some tailpipes on the back end and i thought there mght be a back flow of fumes but they are all clear and sealed up well.
    i t is more noticable on start up,and when your driving it goes away,only when you are in sitting traffic does it come into the cabin.
    i only hope its not the dreaded fuel pump or this high pressure thingy magig watchdog were going on about .but as i said she drives perfect theres no stalling or struggling to start symptoms.
    sorry for the long ask but stumped what to look for.
    Jan 2010
    glasgow
    if your sure its wasnt caused by you messing with the exausts look for leaks if none see if the engine oil is smelling of petrol it could be the pump thats flooding
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I will put money on it it's a split flexi
    Aug 2010
    shropshire
    Quote Originally Posted by paulvectrac View Post
    ooh right ok cheers bud
    sorry to be a noob but what is the flexi
    Aug 2010
    shropshire
    right i think i have found the problem.
    there is a small disc shaped item about the size of 50mm diameter with a pipe either one from the rear and thenext going to the front of the engine.
    there is a small hairline split with a very fine mist of fuel leeking from it
    does anyone know what its called and whats involved to replace
    Aug 2010
    shropshire
    this
    What ever it is you need to change it, with fuel leaking over a hot engine it's a potential fire waiting to happen imo ...........
    At a guess, flame trap?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I remember Benny mentioning this part before, I dont think you can fit just this part, I believe it involves some of the line as well. dont think its a flame trap might be some sort of regulator before the hp pump but i cant remember.
    Aug 2010
    shropshire
    yes from bennys description from another thread i found .
    its a fuel damper and smooths the flow of fuel into the engine and yes its pipes as well as the silver part.
    £50 for the part and vauxhall charge £80 an hour to fit ,robbing b*****ds
  1. Eggy smell in cabin....what could cause this?
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2012, 19:38
  2. Ammonia Smell In Cabin
    By PORKBALLS29 in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2011, 19:32
  3. Smell in Cabin....
    By unreal_event_horizon in forum Engine & Drivetrain
    Last Post: 1st February 2011, 00:57
  4. Fumes smell in the cabin
    By Northy in forum Engine & Drivetrain
    Last Post: 17th January 2010, 19:59
  5. Cabin smell when fan on full speed
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2010, 12:09
vectra c direct 2.2 problem smell of petrol
vectra c cdti sri smell of fuel when heatings on
smell from fuel pump on astra 2.2
zafira 2.2 direct smells petrol
what is the ufo shaped thing in the fuel line on the vectra 2.2 direct
vectra c 2.2 sri fuel smell when heaters on
zafira petrol leak front 2.2
vauxhall omega 2.2 petrol leak
vauxhall 2.2 fuel leak
vauxhall 2.2 petrol smell
vauxhall silver disc fuel line
