Results 1 to 10 of 17
Thread: How to test Cooling Fan
    East Ayrshire
    Trim : SRI XP1
    Default How to test Cooling Fan
    Wasn't sure wether to put this in here or electrical so feel free to move it if needbe. Changed my thermostat today, first time I have ever seen the needle about 80! However, I kept the engine running, wasnt out driving just stationary. And It went up to 90 and still no sign of the cooling fan coming on, Anyone know what temp it comes on at? I'm going to take it for a run tomorrow because I ain't getting any heat out the blowers so there must be a wee air lock
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I think it comes on at about 92C. When my thermostat was bust the temperature would rise to 92C in traffic conditions and wouldn't rise any further. Once I drove off the temperature would drop back down again.
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    My car temp stays at 90 all the time, should I be worried!
    I have blanked the EGR like.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    East Ayrshire
    Trim : SRI XP1
    i think thats about normal mate. I just wasn't sure what temp the fan kicked in at
    Nov 2010
    East Midlands
    Trim : design
    If you use Op Com you can get it to test your fan - I would think if it was faulty it would come up with a fault code
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by leemarksmith View Post
    Wouldn't worry too much about that - there are always slight variations in the accuracy of the temperature gauges and the temperature sensors, and the thermostats are rated at 88 degrees anyway. If Thermostats do fail they usually fail open, which means the engine is always running cooler and does not overheat. Simplest way to test your system is let it tickover until the fans come on and check the temp gauge - should rise slightly and then drop down to normal when fan cuts in. (Good job fuel is still cheap )
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Fan should cut in if you disconnect coolant temp sensor.
    If you don't own any diagnostic kit
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Feb 2011
    Selby
    Normal operating temperature for all the engines used in the Vectra range (and indeed most engines) is 85°C to 95°C. On average in the Vectra it should sit about 87°C - ie just below the thermostat opening temperature. The radiator fan should come on around 92°C.
    The reason for this is that engine lubricating oils work best in that temperature range. So the cooling system works to maintain that range.
    If it's running at 80°C or below, you have a failed thermostat.
  1. Seat cooling
    By Ian-Highlander in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 18:48
  2. Cooling Fan not working?
    By joegingell in forum Engine & Drivetrain
    Last Post: 3rd June 2012, 11:54
  3. Cooling fan
    By nokiaman1978 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd October 2011, 19:27
  4. Cooling fan
    By Marc 100 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2008, 00:01
  5. Office Fan Cooling....
    By spoons in forum General Chat
    Last Post: 18th June 2006, 22:00
testing cooling fan with opcom
testing fan with opcom
radiator fan not coming on vectra c
06 vauxhall vectra radiator fan not kicking in
how to test cooling fan vectra c cooling fan on a vauxhall vectra 2003opel vectra c 1.8 fan temperaturewhere is located the relay of radiator fan of opel vectra c 20021.9 sri vectra cooling fan doesnt seem to cut invectra radiator fan issuesvectra c cooling fan relay locationvectra c cooling fan testing radiator fan using opcomwhen should my electric fan work vectra c 2002 gsi 3.2vectra b fan relay testvectra c coolant fan temperatureopcom cooling van testvecta coolingfans onhow to test cooling fan 04 vectracooling fan test opel vectra bhow fan work opel vectra bsignum 2.2 fan relay1.9cdti engine fan wont come onhow to check engine fan on vauxhall vectrawhat temp should cooling fan come on vectra 1.9 cdti
