Thread: 1.8 VVTi Condensor Help
    Oct 2007
    Ripon
    Default 1.8 VVTi Condensor Help
    A bit of advice required .....
    When I turn on my aircon I get a hissing sound that goes when I turn it off. Only topped up last year so guess something is shot.
    Took a look at the Condensor and it is pretty smashed on the lower fins so thinking it may be shot.
    After looking at these are they suitable for the 1.8 VVTi 58 plate and which one of the two do I need?
    http://www.autoairconparts.co.uk/Vau...tors-and-more/
    Going to have a go at changing, get the system drained and do. Prob put fine mesh behind grill as well.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    I'd do the lower grill as well bud
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Just a thought tho.. If your condensor is leaking - it will leak all the gas out and then the lack of preasure will stop the compressor running..
    So - if you are hearing a hiss - it cant be due to a leak as all the gas would have escaped by now?
    Oct 2007
    Ripon
    Unsure, just getting a hissing sound when aircon switched on, no colder air. Read through some threads and seems the same as others.
    Oct 2007
    Ripon
    Is it easier to get the one with the drier fitted? One listed with and one without ..... I assume they all have them fitted?
  1. Air Con Condensor
    By iain.condliffe in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2011, 20:08
  2. Would You Say Condensor?
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 21:41
  3. What is meant by 1.8 VVTI? is the vvti engine better or worse?
    By Deann in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2011, 11:19
  4. air con condensor
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2011, 12:04
  5. Air-con condensor..
    By tonyo in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2011, 21:28
