Thread: fed up
    Mar 2012
    newcastle upon tyne
    Default fed up
    please can anyone tell me and pics if poss
    crankshaft sensor 1.8 petrol vectra 2003 model
    thank you
    Sep 2011
    Falmouth
    Quote Originally Posted by andrewl6527 View Post
    thank you
    have a look,
    http://www.micksgarage.co.uk/switche...1.8-16v/16531/
    Regular Member simon7257's Avatar
    reading
    I think it's either on the front of the engine but by the gear box or at the back of the engine by the gearbox up behind the drive shaft held in by 1 torx screw (t30?) 2 pin plug at about 45 degree angle, can be very tight to get out cause they swell up
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by simon7257 View Post
    its beside the oil filter IIRC.
    Mar 2012
    newcastle upon tyne
    appreciate everyones help
    problem gets worse.
    changed the crankshaft sensor to find out the car is not a 1.8 but 1.6 and out of a vectra b. and the idiot who changed the enging and not informing anyone has butchered the wiring harness and the wires to the crankshaft sensor so my friend thinks thats the problem.
    i need this fixed asap and not costing a fortune
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    did you buy the car privatly?
    if the engine is different mate and the dvla etc dont know then basically insurance is invalid to.
    have you go voltage to the crank sensor?
    i think your best bet would be to get an auto spark on it, as itll probably be a lot more cost effective than you trying to fix things and finding other problems as you.
    where as a spark or go diagnostic garag with and oscillscope can prove sensors and actuators are working correctly within a couple of minutes
    Mar 2012
    newcastle upon tyne
    just a short update
    been checked by a sensor diagnostics expert and some idiot cut the wires to the crankshaft sensor so it needs replacing and the timing is out so this will be fixed on wednesday. i'll update then
    Mar 2012
    newcastle upon tyne
    right the sensor cable has been replaced and the timing corrected but still cut out once and took 3-5 mins to restart. so any new ideas?
    can the revs be turned up too? it idles at 500 which i know is too low?
    thanks
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Sounds bad mate am shore the revs can be lifted
    Mar 2012
    newcastle upon tyne
    anyone in the Newcastle area do this apart from vauxhall??
