Thread: signum
    Mar 2012
    Bicetser
    Default signum
    I have just changed the fuel filter on my signum 2.2 diesel and it wont start as there is air in the fuel line, any ideas on how to bleed it without loosening the injectors as they are a pain to get to.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Remove lid and refill the filter housing. Tow it is easiest. About 1,500-2000 rpm in gear and she'll go
    Mar 2012
    Bicetser
    I have filled the housing and it still wont go, cant tow as its a semi auto, had it off jump leads but just wont fire up
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Undo injector is the only way i know then. Unless you can use a cheap petrol cap from a garage and make a hole with a pipe to blow through and pressurise the fuel tank whilst someone cranks
    Mar 2012
    Bicetser
    thanks mate, will have another go in the morning,
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    My V6 has a auto bleed on it. You turn the ignition off and on a few times i think. Worth a shot before you get covered in diesel
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    2.0, 2.2 dti and v6 cdti don 't have scavange pumps in the fuel tank. If the filter housing isn't full they get air in.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by mattv6diesel View Post
    My v6 cdti sorted itself out after being instructed by vauxhall to turn the ignition on and off a few times.
    Sent from my HTC Desire HD A9191 using Tapatalk
  1. Replies: 2
    Last Post: 6th October 2012, 23:09
  2. Replies: 5
    Last Post: 5th February 2012, 20:42
