Thread: clutch problem?
    Aug 2011
    lancashire
    Default clutch problem?
    got a vectra c 1.8 ls petrol
    took it out last nite and was on my way home pulled up at the lites, went to lift clutch up but there was no bite? it dosent drive at all in any gear or reverse, it was working fine with no problems before this
    the pedal is still normal not floppy or anything and it gose through gears fine ( wilst i was stationary ), but it just dosent want to seem to bite at all
    any one got any ideas of what it could be ? please as i have not got a clue
    any help much appreciated
    cheers thomas
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you checked the basics fella fluid level etc
    Aug 2011
    lancashire
    fluid level was low, but also my front n-side drive shaft had gone as well,
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    How do you mean gone? If its snapped then there is your problem the diff will always send all of the power to the easiest wheel and in your case the one with the snapped driveshaft.
  1. clutch problem please help
    By v33tra in forum Engine & Drivetrain
    Last Post: 12th November 2011, 02:09
  2. Clutch problem!
    By kel123 in forum Engine & Drivetrain
    Last Post: 5th October 2011, 16:07
  3. Clutch Problem
    By ickleric in forum Engine & Drivetrain
    Last Post: 31st January 2011, 19:19
  4. clutch problem?
    By darko2301 in forum Engine & Drivetrain
    Last Post: 10th April 2009, 21:33
  5. Clutch Problem
    By Aimee in forum Engine & Drivetrain
    Last Post: 30th August 2006, 23:31
