Results 1 to 10 of 14
Thread: notchy 2nd gear
    Regular Member eminemme42's Avatar
    Jan 2012
    westmidlands
    Default notchy 2nd gear
    hi all a vectra sri 150 bhp 54 reg
    notchy going into 2nd gear but fine in all other gears
    any ideas please
    cheers pete
    Regular Member Exclusive BV's Avatar
    West Midlands
    Not had this problem on my vec but i improved the gear selection on our Zafira A by spraying loads of silicon grease on the linkage in the engine bay. I also took the gaiter off (below the gear knob) and sprayed loads on the plastic linkage after cleaning it. It was well mingin.
    hth
    Perhaps the linkage can be adjusted too but i've not tried
    Jan 2012
    westmidlands
    cheers ill have a look 2morrow ill try that
    pete
    Just when cold or all the time? A gear box fluid change can't hurt.
    Jan 2012
    westmidlands
    mainly when cold gets better when warm
    Dec 2011
    Seaham
    If you have a biker mate, get some of his chain lube!! Use instead of grease.
    Jan 2012
    westmidlands
    ar i am a biker too ill try that
    pete
    South east
    I think you're all barking up the wrong tree, there's a How2 for this problem, based on an official Vauxhall fix, and it doesn't involve biker grease or silicone lubricant:
    http://www.vectra-c.com/forum/showthread.php?t=114196
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved to troubleshooting
    Irmscher Insignia CDTI 130
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    Quote Originally Posted by Rebellion View Post
    Ive got this same issue, Had the box oil changed, and no different, So going to changing the clutch fluid in the near future, Once warmed up no issues there for me though.
  1. Gear box oil changed and still notchy gears
    By dannycturbo in forum Engine & Drivetrain
    Last Post: 3rd September 2011, 19:26
  2. Notchy 3rd Gear Automatic
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2009, 18:24
  3. vectra c 1.9 8v adjusting notchy gear linkage ???
    By lollypop in forum Engine & Drivetrain
    Last Post: 26th April 2009, 14:24
  4. Notchy Gear Change...
    By TheMoore in forum Engine & Drivetrain
    Last Post: 26th September 2007, 20:08
  5. Notchy Gearchange
    By BigP in forum Engine & Drivetrain
    Last Post: 1st February 2007, 20:11
