Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: T/C Switch
    Regular Member TonyR999's Avatar
    Cumbria
    Thumbs up T/C Switch
    Fitted a Traction Control switch this morning, AND IT WORKS!!....cost of the switch?...£8....Cost of total satisfaction and smugness?...PricelessI've had the car 3 weeks and so far fitted the rear passenger light, upgraded the front light with the map reading ones, fitted clear side repeaters (hated those orange ones) and now t/c control switch...wot can i do next?????
    Regular Member cameraman's Avatar
    Leicester
    Lucky sod, how about sunglasses holder, door pins, alloy pedals etc
    Cumbria
    Hi cameraman, already have the sunglasses holder ...rather fancy changing the door pins tho...is it an easy job to do?...and maybe chrome wing mirror covers, do you think they would look ok an Saturn Blue?
    i'd hold off the covers.. not sure about them on a blue car ( sorry mrs D )... the door pins thou are sooooo simple to do.. you'll do all 4 and have a tea in 15 mins..
    Regular Member vectravirg's Avatar
    Bolton
    Still frightened of doing the rear passenger light
    Cumbria
    Thanks for the advice Gsi3.2 may just do the pins next, and to vectravirg, like you i was terrified, i mean i only had the car a week and i was already taking the inside to bits just follow the how 2 on doing this...take your time, get good decent sturdy card to make a template and also be careful with the sticky tape under the roof lining and you find it a breeze....well worth it mate
    Cumbria
    Right, going back to original post, i took my car out earlier to make double sure the switch was working...result is, orange light on i get wheel spin, orange light off, no wheel spin ...however....i thought that t/c cut in when you reached a certain speed (something like 35 to 40 mph)...i did speeds up to 70+ mph, the orange light stayed on.
    Does this mean i have `full` control of the t/c?
    Leicester
    Sounds like you have full control of the TC I have ESP on mine & if its off its off!, Door pins are a doddle although you may have to clear the burr off the inside of the new pins before you fit though.
    chesterfield
    Hi all,
    Can I just ask, if I was to buy the tc switch from the dealer, would that mean the car would have tc
    surely it cant be that easy?
    sorry if it sounds a silly question
    Cumbria
    Hi Riskworld...its that easy...was with mine anyway ...but i belive it is a lottery whether you can have it or not....remove the blank plate below the alarm button and if there is a `blue` connector, you may just be in luck
  1. Small 12v Auto circuit for on/off switch for PDC switch
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 23:00
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  4. t/c switch help
    By kitchcav in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2007, 18:02
