Thread: What have i done!
    Mar 2012
    north wales
    Default What have i done!
    Hi all-WHAT HAVE I DONE?-well i've sold my trusty passat 130tdi sport(02)estate and bought a vectra 150 cdti auto elite estate(06)on a 55 plate.Am i mental or what?-It seems i might be!The passat i bought 5 yrs ago with 100k on it and (apart from a belt and water pump)i've never had a minutes trouble in the 50k we put on it-returning a steady 48mpg.
    Now to my new ride-IT's stunning,with full leather and nearly every extra,sitting in a heated leather seat with cruse contol and a lazy man box is a great place to be-BUT(yeah there's a few but's)on the way home after picking up the car i noticed the temp guage on 70deg-got home and did sme digging(where i descovered this wonderful forum)mmmm common problem- new thermostat-£45 and an hours work and problem 1 sorted.
    Reading this forum i desovered the inlet swerl fault,so i checked mine- sure enough the link bar is lying beside the flaps-so £180 manifold- may as well do the belt and pump at the same time,so £350 more.Car seems to be doing 35 mpg,which i suppose may improve with new manifold and valves/throttle etc cleaned .
    Ive also descovered that auto's and estates have the dpf-so that's me stuffed!I just hope and prey that once i've sorted ALL these 'common faults' i'll have the car i thought i was buying.So what do you think -Am i mad or what?
    Last edited by bigmac; 14th March 2012 at 22:45. Reason: Added paragraphs do its easier to read
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Not mad mate. You joined here. Just wait for someone to pop up and offer to help you fix them £0. then you an spend all the money you saved, on mods. You dont even need to tell the Mrs
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    After getting that lot sorted you will not regret it. do a search for your faults as they have all been covered by others on the forum. If anyone knows the fixes it will be the guys on here.
    3.2 v6 Signum and loving it
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    Welcome to the site mate
    Full Member Big Sig's Avatar
    Its getting to the point that all modern diesels have dpf's so we may as well get used to them.
    Jun 2011
    Herts
    did you buy from a stealer?? if so get him to fix the broken bits.........
    If not then at least you'll know the car is right once you've done the bits needed.
    there is a reason veccys are cheap but once the niggles are done they more than make up for the headaches when they start making you smile.
    welcome aboard :-)
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    All cars have issues, just be glad you bought an auto, no DMF to worry about. Might be worth checking if the 3rd injector wiring has been looked at.
    Chelmsford
    Quote Originally Posted by FLOB View Post
    Seconded...
    I've spent many hours under the car recently, done all the suspension (new shockers, bushes, the lot) and some engine work. It seriously drives like new (touch wood, undoubtably something will break tomorrow now I've said that!)
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    At least you're free from the Overboost Problem on the VAG TDI's caused by sticky VNT vanes!!
    Welcome to the site. Dave.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    welcome fella
