Thread: Battery 1.8vvt
    Fife
    Default Battery 1.8vvt
    Hi guys, I am sure this is prob a daft question but hey ho! I am needin a new battery. Am gonna buy online just to save a few £'s but does the 1.8vvt use the same battery as the 1.8? If not what should I be lookin for?
    I apologise the for thickness but I am defo not a car mechanic of any sort
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Just make sure the Ah (amp hour) number is the same or higher. Normaly about 35-45 ah on a petrol
    Fife
    Quote Originally Posted by mattv6diesel View Post
    cheers mate!
    Dec 2011
    Seaham
    There should be a sticker on the battery that states its current specifications.
    Get one the same, or better!
    Regular Member simon7257's Avatar
    reading
    Amp hour is important but look at the cold cranking amps the original Vauxhall battery will be rating using (din amps) which is written on the top I think from memory the battery is an 027 battery which is rated at about 550 EN amps, go on something like euro car parts website where you can type your reg in and get the exact part number
    Regular Member DurhamRed's Avatar
    Co. Durham
    Vehicle : Vectra SRi
    Engine : 1.8VVTi
    Battery number 075 is correct. recently changed the battery on my 58 plate 1.8 VVT SRi. Paid £48 for one from my local motor factors, battery came with a 3 year guarantee.
    I was a bit disappointed that the original battery hadn't lasted longer though.
    reading
    Thought it might have been an 075, the 027 and 075 are basically the same battery the 027 is slightly taller and a bit more powerful, you have plenty of room in there to take a much bigger battery like a 100 or even a 110 which is fitted to the diesels, bigger is always better the don't work as hard and for that reason last longer
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  3. 1.8vvt
    By platts007 in forum Engine & Drivetrain
    Last Post: 24th August 2011, 20:24
  4. 1.8vvt
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2011, 11:48
  5. 1.8vvt
    By starykokot in forum Petrol Engine related
    Last Post: 2nd May 2011, 20:26
