Results 1 to 10 of 18
Thread: check height of front please.
    Regular Member nick-v2.2's Avatar
    Nottingham
    Default check height of front please.
    Vec C on 18's with bilstein b4's and 30mm eibach springs.
    I know this will be a common setup.
    Can someone please measure from the floor to the highest point of the wheel arch on the front.
    Went to get alignment done. They said one side was scraping going up the ramp.
    Because its lowered anyway didn't think much of it. Checked tonight and there's about 3/4 inch difference from one side to the other.
    Jun 2011
    Herts
    I doubt it really matters what height others are at- one side of yours is wrong somehow. looking at the 2 sides and comparing will be the easiest way to find out.
    Is it possible that one of the shocks wasn't nutted up tight aand is unwinding itself???
    or could a bump stop have been left out???
    I've not heard of eibachs snapping.
    or could the springs be different weight ratings????
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is spring sat in its seat properly?
    Nottingham
    ok drivers side is 26' 2 passenger side is 26" 9. a 17mm difference.
    I have checked the bottom of both springs and both seem fine.
    I have also checked the bolts on strut top and they are fine.
    Both bump stops are fitted.
    The ride height was fine 2 months ago
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    When you press down in each corner do they react the same?
    Should rise up, go down then settle.
    The drop link is attached?
    Jun 2011
    Herts
    try jacking it up of the ground and twist the springs out of and then back into the correct position-and get a good look at the top end as a broken end would be hard to see up there........
    never thought about it being a loose or totally shot droplink............... worth a look too
    Nottingham
    will try it as soon as possible.
    Drop links are only 3 weeks old.
    Nottingham
    Default front suspension/problems
    After a lot of help from DitchpP and to Husky for supplying two new front shocks.
    Still no further forward.
    So far rich has checked both my shocks, top mounts and bearing, swapped the springs over and replaced the shocks.
    The drivers side is still sitting 5mm lower than the passenger side. It has not long been in for wheel alignment and nothing was pointed out as broken or damaged.
    there was a thread on here recently about the front subframe being out of shape. But there is an equal gap between wheels and arch horizontally.
    Any ideas or suggestions would be appreciated. Bent Wishbone has been suggested. Otherwise no idea as to what could be wrong.
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    122 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    it may sound a silly suggestion but have you checked your rear suspension?
    The reason i say this is because in theory if say your drivers side rear suspension is worn or broken and is sitting lower it could have the effect of lifting the passenger front ?
    i know its a weird suggestion
    Nottingham
    hi jon.
    I have compared the rear suspension a few times also and they are equal height both sides.
  1. Wheels refurbed, Check - Car Buffed and Polished, Check! !
    By messermitch in forum Quick Photo Album
    Last Post: 18th July 2012, 23:18
  2. how to check if front window tints are legal?
    By mann3210 in forum General Chat
    Last Post: 23rd May 2011, 20:02
  3. Pedal height...
    Last Post: 18th October 2010, 14:12
  4. ride height
    By pidge in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2010, 17:59
  5. SRI ride height ??
    By Mickyboy in forum Suspension, Wheels & Brakes
    Last Post: 18th March 2010, 12:05
