Thread: 02 Sensor
    Jan 2012
    Darlington
    Default 02 Sensor
    Hi
    Got a fault code p0037 turns out to be the rear O2 sensor could anyone tell me what it does ?? its £151 just to buy a new 1 from my local dealer and don't really want to spend that money as the car seems to run fine odd misfire on tick over every now again but i'm putting down to plugs
    Andy
    Regular Member simon7257's Avatar
    reading
    The rear o2 sensor just monitors the fuelling after the cat if you watch it on live readings using diagnostics it should be a flat line or constant voltage depends what your looking at
    Jan 2012
    Darlington
    Hi
    Looked at it on live reading front jumps all over the rear stays at 0.459 is this is right why do i keep getting p0037 code ??
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    What engine sired was that at?
    Can see what fuel trims are reading?
    Are you able to record an see what O2 says at say motorway cruise speed?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Jan 2012
    Darlington
    i only know how to do basics lol it stays same most of the time gives a little flicker when i rev it tho just looked at fuel trim think b3 was 0.0 and didn't get a reading for the long term
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Does it go into closed loop operation when at cruising speed?
    Do any values change if you create an air leak or squirt some carb cleaner through intake?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Jan 2012
    Darlington
    Not sure about closed loop how can i check it i'll try carb cleaner 2morro
    reading
    sensor 2 should only be reading constant this is just showing the ecu that the fuel trim adjustments from sensor 1 and the cat are doing there job, if your getting arratic readings then it could be the cat at fault but you would expect to have the horrible eggy smell or a rattling cat, it could be just a faulty sensor or the fueling is so far out that sensor 1 and the cat cant cope
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
