Thread: F40 Gearbox
    Jan 2012
    Darlington
    Default F40 Gearbox
    Hi
    Still having probs with my f40 gearbox crunching 1st to 2nd and 2nd to 3rd.
    I've changed the gearbox oil only putting 2.4ltrs in and reset the sincromess and its no better.
    Can anybody help
    Andy
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    They just crunch i think mine does sometimes when cold but is alot better when warm
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If its only when cold I wouldn't worry.
    Their is a fix I remberd seeing on auto data.
    Butsure requires new bearings
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    South east
    Quote Originally Posted by Critch View Post
    No, the only fix on TIS for the F40 is the reduction in oil level. It even says that if this doesn't sort the problem, don't try anything else as there's nothing else to do.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Well autodata lists :
    Problem:
    Difficult to change between 1st and 2nd when transmission cold
    Cause;
    Sliding gear sticking
    Remedy;
    Repair kit 9201451
    note: modified gear introduced as of transmission No. GXX0320969 10/03
    Ensure clutch system is bled
    Ensure gear linkage is correctly adjusted
    If problem still occurs fit sliding gear kit
    It is not necessary to replace entire transmission
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Double post
    Jun 2011
    Herts
    is you thermostat and sensor working ok?? mine was a porker in all gears when the stat was playing up. just a thought ;-)
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Is your flywheel on its way out. Makes a massive difference to engaging gears.
    Jul 2009
    Brighton
    Try a tube of molyslip in the box. Helps a bit.
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
