Thread: Temperature gauge problem
    Sep 2009
    Consett County Durham
    Vehicle : 52 Vectra c LS 1.8
    Question Temperature gauge problem
    Hi,My temp gauge was staying at zero only rising when in traffic idling,so i had a new thermostat fitted this solved it for a while but after a few weeks it has reverted back to the zero reading,any ideas what is going on,i thought maybe it could be the sender but could be wrong.Regards Martin.
    Engine : 1.9 CDTi
    Yes it could be the sender.
    Did the new one not come with a new sender?
    Sep 2009
    Not quite sure i will have to ask the garage who fitted it as i nevered bothered to open the parcel i had delivered.Regards Martin
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Check its plugged in fully. The wire connector on the plug sort of clips in then if pushed harder clips a second time. Might of come a bit loose.
    Feb 2011
    Selby
    What type of engine is it? I had a replacement thermostat fail in a matter of months on my Z18XE. The first time I only replaced the thermostat, keeping the original housing and temperature sensor. The second time I fitted a replacement genuine GM housing (which comes with thermostat and sensor) and it's been fine since.
    Examining the old housing, I found the thermostat had worn a groove in it, meaning that although there was nothing wrong with the thermostat itself, it would never seal properly, so act as if it had failed because the coolant could get past it.
    Which is probably why Vauxhall won't sell you a thermostat without a complete housing assembly for the Z18XE...
    Jun 2011
    Herts
    a new sender is about 10quid and takes about 10 mins all in to fit so I'd start there as its probably that. but try ehat the others say and make sure it's plugged in tight first.
  1. Temperature gauge
    By any-mgzt in forum Engine & Drivetrain
    Last Post: 8th December 2012, 23:33
  2. temperature gauge
    By rfc52 in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2012, 15:20
  3. Temperature gauge
    By ziggy1 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd November 2012, 02:35
  4. Temperature Gauge problem
    By Trembem in forum Engine & Drivetrain
    Last Post: 22nd February 2011, 20:08
  5. 2.2 Dti temperature gauge problem
    By j88nya in forum Vectra C / Signum Troubleshooting
    Last Post: 26th October 2010, 14:44
vectra 1.9 cdti sri temperature gauge not working site:www.vectra-c.com
