Thread: egr prob
    Jan 2012
    south devon
    Default egr prob
    i have problem with egr on my 1.9 cdti 2005 is it good idea to put blanking plate in iv seen plate for sale would it go in between cooler pipe and manifold any help appreciated thanks
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    The small oval gaskets will do (150 or 120) and fit from the exhaust inlet pipe to the EGR (either/both places on the 120).
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Bit of coke can and a 8mm hole works as well as anything you can buy.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by Gavin2.6 View Post
    Coke cans burn through in time, and a 8mm hole what for? There is no point doing it if you're going to put a hole in it. Either blank it or leave it.
    Nov 2009
    Portugal
    Buy a Fiat plate/gasket.
    worth the pennies ...
    This one´s for the 150 version, (cost-me about 4 gbp) but there´s an oval plate for the 120. Ask a Fiat/Alfa Romeo dealer or search this forum for references and number parts.
    Liverpool
    You need the small hole to avoid getting the warning light on. Also helps increase the air flow speed moving through the valve slowing down the build up of soot. Wonder why the OEM supplier for the engine started using the same method. Kindly pictured above
    Coke can on my 2.6 v6 has lasted 2 years without issue and that thing gets a lot hotter and more abuse than my cdti.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Ask yourself why people blank them, and then whether these 'restrictor' gaskets will do the same job? OEM went down this route due to the number of EGR failures, but why do only Fiat do them, and not VX, or Saab?
    If you want to rid the effects of the EGR then it needs to be fully blanked - yes you will get the emissions light, but so what, better than the alternative.
    As for material, at the end of the day its upto the individual what they use, but for the sake of £4 off ebay, is it worth the risk?
    Aug 2009
    Wakefield
    I agree that you should either blank it or not, not much point in restricting the flow with a smaller diameter hole, the crap is still getting into the enngine. Blanking the EGR is a very popular mod on motorbikes, its much simpler there though as a lot of them dont have ECU control of that....
    I blanked mine last night, 57 plate 150 CDTi, and so far (70 miles) I havent had the EML come on...... I bet it will now I've said that.... I'm booked in for a remap on friday though so if it does it will soon be gone!
  1. Air con prob
    By graycbox in forum Introduce yourself.
    Last Post: 19th July 2010, 22:15
  2. ABS ecu prob
    By CBag7 in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2009, 13:12
  3. i think i have a prob
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2009, 23:09
  4. 2.2 sri prob
    By junior72 in forum Suspension, Wheels & Brakes
    Last Post: 15th August 2008, 22:37
  5. MPG Prob?
    By Basil in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2005, 19:46
