Thread: problem with steering wheel controls
    Regular Member nidgeboy's Avatar
    Sep 2010
    Liverpool
    Default problem with steering wheel controls
    what am i likely too have broke if i remove the steering wheel controls with the ignition on
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    Have you remove them already? I found that when I put mine back on, although they looked like they were plugged in enough they wasn't and I was getting reversed actions from the controls(volume up made it go down etc) took them off and plugged them in properly and no problems since
    Sep 2010
    Liverpool
    Well stupidly I had the keys in the ignition when I removed them and now I'm getting nothing from them. Are they run off a fuse of any type
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Shouldn't have done mate. I took mine off this morning whilst the engine was rinning, waiting for my work colleagues to turn up on site. Still ok.
    WGAF#5
    Have you mad sure there fully seated again ... The clips are pretty touchy when you reconnect them ... Sometimes it's easier to break one of the mountings to ensure they set properly
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    They full or 1/2 can controls. The button type are a stinker to get back in correctly
    Sep 2010
    Liverpool
    Cheers for the replys. They are half can and even just plugged the board in properly to test and getting no response. Starting too wonder if it's my adapter from my headunit that may be the problem all though it's work fine till removal of steering wheel controls
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    only thing i can suggest, is disconnect the battery for half an hour.
    sometimes vectra's have little niggles like this.
    Pulling the battery power and reconnecting it later often forces a soft reset.
    About 90% of electronic / programming hiccups can be sorted this way.
    If this does not sort it, then are you sure that you have refitted everything securely that you disturbed when removing / refitting the steering wheel controls.
    Not implying anything by that statment, but even the best of us forget / miss things occasionally.
    Other than that, is the adapter loom fitted with any in-line fuses, that could potentially have blown? - especially the CAN communication adapter box.
    Last edited by Robsey; 14th March 2012 at 09:35. Reason: poor spelling / missed key strikes.
  1. For Sale: Sri facelift steering wheel c/w steering wheel controls
    By andy.l in forum Parts for sale
    Last Post: 3rd February 2013, 16:08
  2. Steering wheel controls..button V roller wheel
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2011, 18:18
  3. Strange electrical problem regarding radio controls on steering wheel
    By eaglepva in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2011, 17:36
  4. Problem with steering wheel controls....
    By Harry in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2007, 17:52
