Results 1 to 3 of 3
Thread: z20net single mass flywheel conversion
    Nov 2011
    telford
    Default z20net single mass flywheel conversion
    hi there has anybody got a single mass flywheel on their z20net with the original gearbox still being used ? ive just got all my boost problems sorted ready to get the car mapped but im noticing the clutch slipping now and rather than using the original duel mass setup id like to go single mass and uprated clutch as im planing on eventually getting some decent power from my vectra and would like to upgrade stuff as it needs replacing all help would be greatfull as i have been serching the internet and cant seem to find and answers e.g is the conversion possible and what parts are needed or where to get parts from even
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Perfectly fine to do but you need to make sure you get a clutch plate that has the springs built in as this is what the dual mass flywheel replaces. I did a single mass conversion on my last cdti 150 on same F40 box fine.
    Kit on ebay for around 400 notes. Little cheaper than the dual mass versions. Slave and cover the same only clutch and flywheel different.
    Nov 2011
    telford
    ive been having a look on ebay for a single mass conversion but cant seem to find 1 no matter how i put the search details in i beleive that in the vectra b 2.2 they run a single mass flywheel but some people mention a spacer needing to be fitted is this correct ?
  1. Dual mass flywheel conversion.
    By andy-j in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2013, 22:48
  2. Single Mass Flywheel conversion kit
    By dontsnatch in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2013, 18:32
  3. Single mass flywheel conversion
    By GrievousBee in forum Engine & Drivetrain
    Last Post: 13th October 2012, 19:07
  4. Has anyone fitted a single mass flywheel to their 1.9 150 yet??
    By simmo3187 in forum Engine & Drivetrain
    Last Post: 31st May 2012, 16:28
  5. DMF Duel mass flywheel conversion kit?
    By pugs,signum in forum Engine & Drivetrain
    Last Post: 22nd May 2010, 19:51
z20net flywheel
z20net clutch conversion
lightened flywheel z20NET
x20net single mass conversion
z20net single mass conversion
z20net flywheel problems
does a vauxhall z20net have a dual mass flywheel
z20net power issues site:www.vectra-c.com
z20net solid flywheel
z20net vectra c conversion flywheel
