Results 1 to 10 of 13
Thread: CDTi Z19DT whistling/ sqeaking noise
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    Default CDTi Z19DT whistling/ sqeaking noise
    Hello everyone. Car is 2006 CDTi 120bps Z19DT engine. Car drives fine and there is no light on the dash but..........
    ......I have got a whistling siren like sound coming from the engine area when car is idle and also when on the move with accelerator depressed. I heard this first after the exhaust was taken off to get DMF and clutch fitted. I have gone through different threads where the turbo has been mentioned. What am I expecting or likely cause? Could something have been knackered then?
    More recently, with the window wound down due to good weather, I have noticed there is a short/brief sqeaking noise (like a mouse ) that comes from the exhaust area or at least from underneath the car at the very point when I change gears and apply the accelerator.
    Are these two related? Can someone advise what I need to check out please?
    Thanks.
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Year : 05
    Mileage : 100k
    Aux drivebelt idler?
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Is it not the thrust bearing squeaking?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    My CDTi has whistled since the day I bought it. It's loud when cold but quietens down within 1/4 mile. Can always hear it a bit though. Quite like it!!
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    Quote Originally Posted by Casey View Post
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    Quote Originally Posted by DeeBe View Post
    Hope not. this was changed about 5months ago.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 150 Z19DTH
    Year : 08
    Quote Originally Posted by tony-1977 View Post
    Mine continues irrespective of how many miles though can't seem to hear it above 2500rpm.
    May 2009
    Rochford
    Mine does it from around 1300rpm to 2000 ish. Does it when you rev it and when the revs die down. Sounds worse when cold, I think people think its a police car sometimes as I do get people looking behind them to see what coming. Also been told its most probably my turbo. Its been doing it now for a month or so. Don't really want to shell out over 500 pounds to fix it so at the moment I am keeping my fingers crossed it doesn't get any worse.
    Nov 2011
    Cheshire
    Engine : 1.9DT
    Year : 05
    Mileage : 100k
    Mine does it, its one of the idler wheels to do with the Aux drive belt, its on my looooong list of jobs to do.
    May 2009
    Rochford
    I took my aux belt off and it still did it so its definitely nothing to do with the idler wheel. You can test if it turbo related by removing the small pipe from the boost controller fitted to the slam panel on the right of the rad. If you remove the pipe from the controller that goes down to the turbo and then try revving the car. If it still does it, its most probably not to do with the turbo. But like mine it complete dissappeared. This pipe controls the wastegate and keeps it shut as you rev up. So removing it means the wastegate is open so the turbo is not under as much pressure and spinning as fast.
  1. What is that whistling noise....
    By baldieone in forum Vectra C / Signum Troubleshooting
    Last Post: 21st March 2011, 10:15
  2. sqeaking noise
    By arniedavo in forum Engine & Drivetrain
    Last Post: 4th March 2010, 11:27
  3. whistling noise
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2010, 21:06
  4. whistling noise
    By fizler316 in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2009, 16:22
  5. Diesel (CDTi) Whistling Noise
    By Dazza_CDTi in forum Engine & Drivetrain
    Last Post: 10th December 2005, 04:42
z19dt whistle noise when reving engine
Z19DT noise
