Thread: Help needed!!! Glow plug lead removal 2.0dti
    Jun 2011
    Herts
    Default Help needed!!! Glow plug lead removal 2.0dti
    Hi folks,
    I'm intending on changing my glow plugs on saturday and have ordered a bosch duraterm set off the bay for 32quid delivered so happy days there
    but I can not see how the leads come off the existing plugs
    I may be being a bit tick but I cant see any release buttons or lugs to loosen them off so they can be removed and I'm not gonna try to force them....
    I have searched all over but can't find any pics or clear descriptions on this
    can anyone help???
    Steven
    Nottinghamshire
    The black caps have tabs on them on opposite sides. They are flush with the rest of the cap and don't have ridges (to grip them with ) so not the easiest thing to see. You press in the top half (i.e. furthest from the glowplugs themselves) of each tab on each side and this makes the bottom half of the tabs come out and release the cap from the glowplug.
    If you look closely, you can see that the tabs are part of the same moulding as the rest of the plug and move by bending a thin strip of plastic that connects them mid-way down each side to the rest of the cap. You have to press quite firmly as they are quite stiff and the caps may need a bit of wiggling as well, especially if they haven't been off for some time.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by James24 View Post
    The black caps have tabs on them on opposite sides. They are flush with the rest of the cap and don't have ridges (to grip them with ) so not the easiest thing to see. You press in the top half on each side and this makes the bottom half come out and release the cap from the glowplug. You have to press quite firmly as they are quite stiff and the caps may need a bit of wiggling as well, especially if they haven't been off for some time.
    ...and also remember - spray the glow plug base where it screws into the head with plus gas a good few times before you try and remove.
    Remove plugs when the engine is at operating temprature and youll be fine..
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by FLOB View Post
    Hi folks,
    can anyone help???
    Steven
    There are no release button/lugs. Use a plier to hold the top of the connector, sqeeze together gently and at the same time move clockwise and anti clockwise then pull upwards. Should come away easily. Have your 10mm deep socket and spray some wd40 on the plugs before trying to loosen. Goodluck.
    Jun 2011
    Herts
    thanks to all 3 of you :-)
    just had alook and all makes sense now.
    Steven
    Jun 2011
    Herts
    thanks again for your help.
    made myself some improvised glowplug pliers and got the plugs and temp sensor done in an hour.
  1. Veccy 2.0DTI glow plug caps
    By cyberbobdude in forum Engine & Drivetrain
    Last Post: 26th June 2012, 07:10
  2. glow plug removal
    By dieseldave in forum Diesel Engine related
    Last Post: 1st August 2010, 09:32
  3. Glow Plug Removal
    By dhwigston in forum Engine & Drivetrain
    Last Post: 1st December 2009, 14:30
  4. 2.0dti glow plug light
    By piker john in forum Engine & Drivetrain
    Last Post: 28th April 2009, 19:53
  5. vectra c 2.0dti glow plug problem
    By barrymanalow87 in forum Engine & Drivetrain
    Last Post: 17th April 2009, 19:04
glow plug lead plier
