Results 1 to 10 of 13
Thread: Anyone help in advising what gearbox is in my veccie?
    Regular Member kicker's Avatar
    Oct 2007
    West Midlands
    Default Anyone help in advising what gearbox is in my veccie?
    Hi all,
    Well the gearbox decided to have a fault occur this time. I've got loads of teeth of the gears and swarf when I dropped the pan cover and oil.
    What I'm trying to find out is what gearbox do I have as I'm been quoted loads to recondition it/get a replacement g/box. Was gonna try and get a replacement off ebay etc. I under stand there's a code liek F40 etc etc??
    Vectra is a 2003 1.8 elegance = Z18XE?
    Cheers guys if anyone can help.
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    F17 it should be bud.
    Oct 2007
    West Midlands
    cheers gavin. at same time i had a text from a mate who also advised that. but he did say that i need to check if there's a further code like BP or UA on the end plate?
    Any ideas what the difference would be?
    South east
    Send me your reg in a PM and I'll see if EPC states it.
    Liverpool
    Should be either f17-wr or f17-cr.
    Wide or close ratios
    Feb 2011
    Selby
    It might be worth getting the code off the actual gearbox to compare. The following link shows where to find the code and what the digits mean:
    http://www.opel-infos.de/getriebe/f17.html
    I would suspect that an Elegance has the F17CR, but without going out to the carpark to check mine I can't be 100% certain
    Oct 2007
    West Midlands
    Quote Originally Posted by rich r View Post
    Cheers rich, I'll have a look tonight.
    South east
    Received the reg in a PM from OP, the build info on EPC just says F17 5-speed, without mentioning wide or close raio, but when you go to look up the part number(s) for replacement units it only lists the wide ratio, so looks like that's what you have.
    Oct 2007
    West Midlands
    Quote Originally Posted by kicker View Post
    Finally got the number off the gearbox - A05631F17W394.
    tried to work it out on the link but it's in german...lol
    South east
    Derrrrr lol. Even I can decipher that German page enough to read that the "W" near the end of the serial number on your gearbox means Wide Ratio - which is what I found from your reg number anyway.
  1. Light on Dash, Advising Boot Open
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 20:45
  2. My Veccie so far
    By Bishyboy in forum Quick Photo Album
    Last Post: 21st June 2011, 20:52
  3. My Veccie so far
    By stubopvectra in forum Quick Photo Album
    Last Post: 3rd March 2008, 19:12
  4. HUD for your veccie ...
    By Bainie in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2006, 14:16
