Results 1 to 3 of 3
Thread: P0016 Cam/Crank Shaft
    Mar 2007
    Gloucestershire
    Default P0016 Cam/Crank Shaft
    Hi all, for some time I have been having intermittent starting issues with my '54 plate Vec 1.9CDTI 150. At xmas I had all 4 injectors recond as they were poorly and this solved one problem. However more recently the starting issue has returned and the spanner light gives me code P0016 Cam/crankshaft sensor bank A (or something similar). I have read various posts on forums that sometimes one sensor can cause the other to fail, etc, but wondered if anyone else had read this code before and what the fix was. Basically some mornings it takes a few cranks to turn, usually if it doesnt bite in 1-2 seconds I stop turning it over then start again. This is usually when cold but does also happen when warm. For the sake of £55 I was prepared to chuck two new sensors on it to try, but before I do just thought I would ask the question. I know where the cam sensor is but can anyone point me in the direction of the crank sensor - I see the how 2 on here is for a 120 and wondered if this is the same for the 150?
    thanks
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Try cleaning then with some carb cleaner/ contact cleaner
    It Might help
    wirral
    56 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    It Might help
  1. crank shaft sensor
    By dr1v3r in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2012, 19:54
  2. Y20 DTH Snapped Crank Shaft
    By keithtinman in forum Engine & Drivetrain
    Last Post: 15th July 2011, 15:48
  3. Piston and crank shaft - CDTI 120/150
    By zafira in forum Diesel Engine related
    Last Post: 26th November 2010, 21:09
  4. Crank Shaft Pulley???
    By Stephen S in forum Engine & Drivetrain
    Last Post: 1st September 2010, 20:27
  5. Crank Shaft Oil Seal !!!! PLEASE HELP!
    By s0501291 in forum Engine & Drivetrain
    Last Post: 24th April 2009, 19:53
dth p0016
insignia p0016
p0016 opel zafira
p0016 renault
p0016 vectra
p0016 insignia
vauxhall insignia p0016
