Thread: CDTI 150 No low down power.
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Default CDTI 150 No low down power.
    Hi Folks,
    Wondering if you can help with my issue.
    Just picked up a new CDTI 150 as put my last one into a tree at 70 bending it slightly. The new one does not have any low down power. Anything under 2800 rpm there is no boost then all of a sudden it will fly off just on 3000 rpm.
    The car I have just got has had massive amounts of work recently so not sure what the issue could be.
    So far its had new intake manifold and motor, new egr, flywheel, thermostat, glowplugs, glowplug relay, wiper motor etc.
    Checked the boost pipes and all ok. EGR is clean and operates via tech2 fine. glowplugs working ok. tested and come on for 30 seconds and turn off.
    One thing I have noticed is the turbo makes like a feint police siren type noise at about 1400 rpm for a second then goes. When the boost comes it stutters first then blasts off.
    Guessing the turbo may be goosed. If so how can i tell or test or any other ideas. Have been searching like mad but everyone seems to have fixed there issues with above fixes but mine is still sick.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Boost controller?
    Vacuum pipes?
    Liverpool
    Boost controller?
    Vacuum pipes?
    Boost controller? - Cleaned and when checking on Tech 2 it appears to be working.
    Checked and fixed. One small hole in one of the L bends but no fine i thinks...... Can hear it dropping suction on removal of the pipe. Will check if I have then on the correct way around tho lol.
    Lancashire
    Trim : XP1
    Mileage : 66000
    What year is your new CDTi? Some require software updates for new EGR's....
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    I've got a similar issue on my 120 so your not on your own.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Also check your injectors.. Ive seen the '3rd injector' common issue cause hesitation at low revs... Have you had the plug done?
    Along with that TIS field remedy there is indeed a Software update. Had it on mine and it made a big difference to pickup.
    Liverpool
    Its had the 3rd injector changed. Got the blue plug over the yellow.
    Its a 55 plate. I say new as my last one was a preface and new one is a facelift...
    EGR activates via tech2 fine and is extremely clean. Must be only a few k old max. Boost valve was a bit gunked up but cleaned and when viewing on tech2 can see the readings increase with RPM but only really low upto 3k then the readings jump up massively.
    It is not running rough. Just lacks any boost low down.
    May 2006
    scotland
    I would disconnect the EGR electrical connector and take it for a spin and see if there is any difference. Nothing can sometimes beat a real live driving trial. You will get the spanner and emissions warnings lights but these could be cleared with a code reader or will eventually go away on their own account after re-connecting the EGR to the electrical system.
    I have read somewhere that new EGR valves sometimes require an ECU S/W update but am unsure how true this is. Good luck
    Liverpool
    Tried a run without the EGR connected and also blocked off and no change. After a load of cleaning and checking yesterday after testing the egr I got an intake air leak error so guess thats next to check out. Cleared the code and went for a drive and its not come back but car still well under boosting low down.
  1. 120 CDTI low on power
    By Boris in forum Engine & Drivetrain
    Last Post: 27th May 2012, 00:04
  2. little power 150 cdti
    By smokydiesel in forum Engine & Drivetrain
    Last Post: 26th May 2010, 19:13
  3. 3.0 cdti can you get more power from it??
    By m3ath3ad in forum Diesel Engine related
    Last Post: 6th May 2009, 23:09
  4. 150 Cdti down on power??
    By shrekster in forum Engine & Drivetrain
    Last Post: 7th December 2008, 00:19
  5. Another 1.9 cdti 150 with no power, low rpm
    By bigboss in forum Engine & Drivetrain
    Last Post: 10th April 2008, 16:58
z19 cdti max boost
