Thread: 2.2 dti sri back discs n pads
    Mar 2012
    Doncaster
    Default 2.2 dti sri back discs n pads
    Just changed discs n pads, now there rubbing and slowing mi down , is this normal, do they ware in??
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Front or rear - not normal to rub enough to stop you!
    Mar 2012
    Doncaster
    Quote Originally Posted by AntSSSS View Post
    Rear mate, there putting groovs in the discs already, somets wrong big time
    Middlesex
    Trim : SRI
    Mileage : 100k
    Did you wind the pistons on the calipers right in when you fitted the new disc's and pads?
    If not - try doing that.
    Clamp brake pipe and open bleed nipple before you do
    Can help - but often points to sticking calipers im afraid and will need changing..
    Middlesex
    Trim : SRI
    Mileage : 100k
    also check that the handbrake cable isnt too tight / caught..
  1. changing discs and pads, pushing pistons back.....
    By taffy bhoy in forum Suspension, Wheels & Brakes
    Last Post: 9th October 2012, 22:33
  2. Normal For Back Pads & Discs To Wear Before Fronts
    By Geordieman in forum Vectra C / Signum Troubleshooting
    Last Post: 12th April 2010, 18:04
  3. Replies: 1
    Last Post: 21st October 2008, 15:11
  4. Can you fit 314mm discs to replace discs on back wheels of a GSi 3.2???
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 21:10
  5. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
