Thread: Alot of oil around injector 1 and 2
    Aug 2011
    accrington
    Default Alot of oil around injector 1 and 2
    Can anyone help I have a 54 vectra cdti 120 and seem to have a lot of oil around the first and second injector can anyone shine some light on what as coursed this happen as it starting to burn and smell inside the car. I have pictures of it but I can't upload them until I get my laptop back to show where I mean
    Dec 2011
    Seaham
    Are the injectors leaking?
    Aug 2011
    accrington
    what i can see i think its leaking on to second one but there is that much crap round them i can't really tell i have pictures but there not brilliant but it does show what i mean with all the oil
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Injector seals
    Mar 2007
    Gloucestershire
    As critch says...injector seals. Easy and cheap job, albeit I would tackle it soon before the crud around the injectors gets too bad, as that will make it a pig of a job to remove and clean if it has been happening for a while. Good How 2 on here....albeit its for a 150, but same principles.
    Dec 2011
    Seaham
    Give the area a good Gunking before you start to strip it down. Work the de-greaser in with a paint brush, then there is less chance of bits of much getting in the way of the new seals.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Hot engine turned off
    spray with Mr Muscle oven cleaner (foam type)
    leave for 10 mins
    jet wash off
    Will be nice and clean
    Then replace seals - job done
    Aug 2011
    accrington
    it already bad enough back there will give it a try when i find the how to! stupid question i know but i heard you need a tool to remove the injectors or are they pretty easy to get off with just normal tools!
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Depends how much crud is holding them in.
    But usually big of wiggling maybe a few soft tips with a rubber hammer gets them out.
    Their is the possibilty it will need a puller but you won't know till you try
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
  1. Seems alot of road noise
    By Angel1368 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 09:46
  2. alot more mpg from non supermarket fuel.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2011, 17:22
  3. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  4. not alot on ebay for vectra c
    By pogo in forum General Chat
    Last Post: 23rd September 2006, 05:36
