Thread: 2.2dti knocking when foot off throttle
    Regular Member krazylegz's Avatar
    South Shields
    Default 2.2dti knocking when foot off throttle
    Anyone know what would cause my 2.2dti to make a knock sound when I I accelerate then lift my foot off a bit, it's not a constant knock just once each time I do it.
    Is there any mountains that are prone to going in these that could cause this?
    Dec 2011
    Seaham
    Engine mounts could be soft or sheared?
    Get a hold of the engine and rock it backwards and forwards and listen for knocks.
    Exhaust catching? Have you had a nw exhaust fitted badly?
    South Shields
    Well I haven't touched the exhaust as not long had the car but it does sound like it has a slight blow so will get under to check it....... Cheers mate
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The DMF might be weakening, the clutch might be on its way out, the wheel bolts might be lose... How long is a piece of string (assuming it to be nylon, 2.5mm thick and cut with a knife).
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by nutron View Post
    But seriously.
    Could be anything, mine did this and never got any worse. I just ignored it to be honest. Possibly a worn engine mount - was on 200,000 miles but I never managed to pin it down.
  1. 2.2dti clean throttle body
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2010, 14:26
  2. 2.2DTI losing power and knocking noise
    By Celes in forum Engine & Drivetrain
    Last Post: 5th April 2010, 03:25
  3. '03 2.2DTI Signum Throttle Body suspect
    By garthmatthews in forum Engine & Drivetrain
    Last Post: 23rd December 2008, 01:56
  4. Vectra 2.2dti "grumbling/knocking" noise
    By Peetoki in forum Engine & Drivetrain
    Last Post: 17th February 2008, 14:51
