Thread: Signum MY 06 - Jacking points - Plastic !!!
    Luton
    Exclamation Signum MY 06 - Jacking points - Plastic !!!
    Just a word of caution when jacking - the oblong jacking pads under the sills are made from plastic. They are heavy duty plastic, but they just plug into the sill member with a rather flimsy single `fir tree' type fixing. Be careful not to put any side load on at all. Not nice (or words to that effect !).
    Been there, done that *lol* I had a trolley jack which was just the wrong size and the whole block came off !!
    Yep, you've got to be careful!! You're much better off jacking off part of the sub-frame - far sturdier!
    Ooooeerrrr missus
    Luton
    Mmm .... I looked for `hard points' underneath on the sub - frames but they are not very easy to get to with a trolley jack. And the longitudinal floor beams taper down and vanish under the rear passenger floor. Not a good car to jack - and I've jacked quite a few in my time !
    There are definitely a couple of good points that I've used with a trolley jack on my Signum. I'll see if I can get a couple of pics for you. I agree, the rear points are the trickier one. You need to come forward down the car a fair bit before you can get a suitable point.
  1. Front jacking points, and using axle stands
    By PeterVV in forum General Chat
    Last Post: 25th July 2017, 14:27
  2. jacking points
    By Kev_1664 in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 17:41
  3. Jacking points
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2009, 19:33
  4. 03 plate Signum V6 Design plastic sills ?
    By mammix2 in forum Styling
    Last Post: 28th July 2009, 15:16
  5. Trolley jacking points & Axle stand locations?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2009, 14:26
vectra c jacking point pad
