Results 1 to 10 of 19
Thread: Car with spanner warning light
    Jul 2011
    Default Car with spanner warning light
    Hey everyone after some help. Was driving on Friday and went from a 30 mph limit to a 60. As I put my foot down and got to around 3k revs there was a small jolt and then a car with a spanner light came on in the rev counter
    When I stopped and turned the engine off and then on again it went and has been fine until today when the same thing happened again.
    I have recently had a new battery and wondered if this could be anything to do with it?
    I do have a warranty from where I got the car from until june so I can take it back and get it fixed but if it's something simple that I could fix this would save me the hassle of taking the car back to be fixed.
    Any help would be greatly appreciated.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    You need to get it back and have the fault code(s) read mate..
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    also some more details on your car would help fella
    Jul 2011
    It's a 2004 2.2 Sri petrol. The non direct one
    Sorry should of put that.
    Jul 2011
    Jul 2011
    Sorry for the double post stupid iPhone keypad and fat fingers!!!
    Jan 2010
    Windsor, Berkshire
    Hi guys,
    Sorry to bring back an old thread but I found this thread in google when trying to search my issue and im having EXCATLY the same issue accept its happens about about 4.5K 5K RPMs. I don't have any fault codes at this time (its booked to go into vauxhall who will get some I guess) but just wanted to see what people thought it could be.
    I have an 04 Vectra 2.2 Direct (Z22YH) - it started about a month ago and happens every so often but not all the time.
    Its just had a full service with spark plugs changed so thats ruled out at least
    Cheers.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 127000
    the spanner warning light could mean a number of things
    we really do need the codes
    does it mis fire?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    sound like my car did the same. the boost drops maybe boost hose leak. just a thought. til codes are read!
    Just remember... all codes do not mean its the thing that are causing problem. it can be something else that cause that thing to not work correctly hence the code. if this makes senses? so give all codes.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 127000
    it maybe your coil pack a member on here had a miss fire and his contacts on the coil pack was cracked
    always a bit awkward without a code
    keeps us updated
  1. Spanner Warning Light
    By TAL in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 18:13
  2. Spanner warning light
    By olearysp in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 21:41
  3. car and spanner warning light
    By paul515 in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 01:49
  4. Spanner warning Light
    By slipperysam1984 in forum Troubleshooting
    Last Post: 6th June 2009, 17:00
  5. Car with spanner warning light
    By DennisTheMenace in forum Engine & Drivetrain
    Last Post: 23rd March 2007, 07:47
what does a car and spanner mean on vectra c
vauxhall car with spanner warning light
car with spanner warning light vauxhall vectra
vectra car with spanner warning light
