Thread: help
    Mar 2012
    newcastle upon tyne
    Angry help
    hi guys
    id appreciate the help with my vectra
    its a 2003 1.8 sxi 5 door
    the problems are
    1) hard to start... turns for ages then starts (sometimes) have changed the plugs with no difference
    2) sluggish. when revving it goes to 4000 rpm and no further and when driving its got no go from 70mph
    3) few noises when going over bumps from the rear but i think thats the sub frame
    4) noise from the steering pump like a whine ive checked the obvious to see if it was low on fluid but its full
    any advice is most welcome
    thanks
    andrew
    Dec 2011
    Seaham
    What mileage has the car done? Does it have service history? When was it last serviced? Are there any fault codes registered?
    Sounds like it is in a limp mode?
    Mar 2012
    newcastle upon tyne
    it was serviced this weekend. theres no history with it, ive had it 2 weeks now
    mileage is 95600
    no fault codes on it at all
    if in limp node would it still get to 70 on the motorway?
    Dec 2011
    Seaham
    What was done in the service? Has it run like this since you bought it?
    Maybe the throttle bodies need a clean out?
    Mar 2012
    newcastle upon tyne
    thanks for the quick reply
    oli and filter. air and pollen filters
    it was a but lumpy when i got it yes.
    throttle bodies? im a novice where cars are concerned
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    Should have had a full belt change at 60k if you don`t know do them anyway. Just did mine at 75k and it was a matter of miles from snapping and writing the engine off. So no history involves new plugs, air filter, oil and fuel filter change. After you have those read the fault codes again.
    And somebody please change the thread title.
    Chelmsford
    No fault codes at all? Have you had it on diagnostic kit, or is the engine light just not coming on?
    If the revs are stopping at 4000rpm, it sounds like limp mode to me, in which case the light would be on.
    Does the engine light come on with the first/second stage of the ignition? Sounds like the bulb might have gone!
    Chelmsford
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    No mention of spark plugs being changed ? try the simple things first
    assume its petrol ?
    Mar 2012
    newcastle upon tyne
    yes the plugs have been changed
    no lights on the dash when starting
    yes its a 1.8 petrol
