Results 1 to 3 of 3
Thread: Gearbox oil problemo
    Regular Member Mikey4996's Avatar
    Mar 2011
    Aberdeenshire
    Default Gearbox oil problemo
    Right guys, real big problem today, hoping someone can help.
    I had the day off so decided to change the gearbox oil, have done on my old vauxhalls no problem but the vectra fill plug was solid in the threads, after rounding the hex key hole i tried bashing in a big torx but still wouldn't come undone.
    So how would i remove this filling plug?
    I have had a good look and the only way i can see is to remove the engine/box mount an try get a mole grips onto it.
    Anyone suggest anything else?
    It will be next weekend before i get anything done due to work and i will have to order a new plug anyway.
    Its a 16v f40 box.
    Cheers.
    Sent from my iPhone using Tapatalk
    i had the same problem with the drain plug on my f40 box
    i ended up using a sharp chisel and knocking it round to undo it then replaced it
    South east
    Surely you can get good access to it by removing the battery and its box?
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Got a Problemo.
    By adam_starkie in forum Engine & Drivetrain
    Last Post: 17th March 2011, 15:58
  3. dash problemo ( light )
    By cruicky27 in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2010, 14:52
  4. 3 button key problemo
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 07:17
