Results 1 to 10 of 11
Thread: Vetra cdti 120 won't start from key
    Regular Member kirkyoke's Avatar
    South Yorkshire UK
    Default Vetra cdti 120 won't start from key
    Hi Folks
    Vectra cdti 120 (2004) will not start off the key either hot or cold, battery is fine it turns over normally but will not fire, however it will bump start no problem, once running it's fine until you switch it off again even if only for 5 seconds, had the codes read and it comes up with :-
    P0002 Fuel Metering Solenoid Valve Circuit Range/Performance
    P0090 Rail Pressure Control Solenoid Valve Circuit Range/Performance (Positive Deviation)
    A friend suggested the high pressure pump weak?
    Any help greatly appreciated,
    Regular Member C-Owner's Avatar
    May 2011
    South London
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Pressure regulator faulty possibly.
    South Yorkshire UK
    is that the one on the back of the high pressure pump or the one in the rail? Live data in opcom shows 12-13MPa when cranking, desired pressure is 30.00MPa,
    thanks
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    It will be on the back of the pump.
    As meters the amount of fuel sent.
    What pressure do you have once it's running?
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    South Yorkshire UK
    30-32Mpa when it's idling,
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Can you read engine rpm whilst cranking?
    Also are them readings rail pressure?
    Think ideally you could do with an actual pressure gauge being plumbed into various parts to confirm pressure.
    You could try shorting the pump to earth when cranking to see if that makes it start.
    This will prove is pump is able to produce enough pressure.
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    South Yorkshire UK
    yes that's the common rail pressure, will check tomorrow what the rpm is whilst cranking (it's turning plenty fast enough to start it), when you say "short" the pump to earth, how would i do that?
    thanks,
    dave
  1. vetra 1.9 cdti cold start issue
    By all vaux in forum Engine & Drivetrain
    Last Post: 21st December 2011, 20:33
  2. Vetra c Meeting????
    By harley270906 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2010, 21:31
  3. vetra sri 19cdti help
    By davy006 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2009, 22:00
  4. new vetra owner
    By nastypablo in forum Introduce yourself.
    Last Post: 19th March 2009, 23:52
  5. 54 Vetra CDTI Design Estate (150) With Many Extra's
    By DeanF in forum Cars for sale
    Last Post: 9th October 2008, 21:31
