Thread: egr
    Dec 2011
    oxford
    Default egr
    Hi
    car through up a warning light last week, turned out to be egr valve.
    Im waiting for new one to arrive but now car has broken down.
    Strarts fine but cuts out when trying to move.
    Is this the egr or something new??
    des
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    I could be wrong, but i dont think the EGR would do this.....sounds more like an induction issue, throttle body or Idle valve (If these have them?)
    Dec 2011
    oxford
    Default egr
    Sorry forgot to say car is 1.9 cdti 2006 120
    update
    Car started and ran ok today.
    Gave it a good thrash to clear it out ran fine but quite a bit of smoke.
    No smoke when at idle or reving only under load.
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Maybe sling some fuel treatment in too...Cataclean, Wynns Diesel Power 3/ Wynns Diesel Clean 3 or Millers Ecomax.
    Dec 2011
    oxford
    Default egr
    thanks will be doing that MadOnVaux!
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    I can highly recommend Cataclean...as ive personally had positive results in every car ive used it in...better running and better MPG.
    May 2006
    scotland
    Note: - I am talking about a diesel here, not a petrol.
    EGR would usually cause the car to run ruff (really ruff if bad) and into limp mode but not to cut out.
    The butterfly on the throttle housing however, if the electrics are dodgy (which they have been know to be in this area), could cause the throttle body valve to snap shut and this would cause the engine to die.
    If you get the cutting out again, as a temp trial, remove the electrical feed connector to the throttle body. Again, this is only for a diesel.
    Dec 2011
    oxford
    Default egr
    thanks for info
    egr valve came today being fitted tomorrow car still running ok at moment
    May 2006
    scotland
    Quote Originally Posted by dustydes View Post
    thanks for info
    Did you fit it and is it going ok with the new one?
Millers Diesel Power Ecomax in vectra c www.vectra-c.com
