Thread: Speaker wire, which is which?
    Jul 2011
    UK
    Default Speaker wire, which is which?
    I am about to wire in a pair of rear tweeters. What wire is + and what wire is -. I don't have access to a Haynes manual and I'm not sure what wire colours relate to each polarity. I'd like to know the colours before I attempt the job as I dont already have the additional loom in place. Cheers
    Jul 2011
    UK
    boinkty bump
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Okay.. your rear wires will be paired
    rear left positive = Green
    rear left negative = green with brown stripe
    Rear right positive = white
    Rear right negative = white with brown stripe
    negative always has a stripe on it.
    Also - to confirm, the speakers themselves will have a + and a - stamped close to the pins for each wire.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Also, it shows you the pin outs on the top of the head unit. You could work it out from there.
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Depends if he wants to mess about getting the head-unit out.
    Jul 2011
    UK
    Guess I could have done, the CD30 is in a box under the stairs atm.
    Thanks for the info
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    It shows the pin out, but not the colour code..
    you would need to refer to the Quadlock connector, and then refer / compare to the pin out on the CD30... what a faff!!
    Jul 2011
    UK
    Just found an unused reel of Halfords speaker cable in my garage, must be at least 15 years old.... lol just the job!!
    Jul 2011
    UK
    All fitted and sounding good!!
  1. Speaker wire plug adaptor
    By wright8672 in forum Electrical & ICE (including SatNav)
    Last Post: 11th January 2013, 18:55
  2. speaker wire colours for + -
    By crazy-dee in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2011, 21:32
  3. Speaker wire...
    By danBoy in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2009, 16:56
  4. Removed alarm speaker wire and now get error
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2009, 13:50
  5. autoleads speaker wire to rca adaptor
    By deano1 in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2009, 09:43
speaker colour code for vauwhall vectra c
