Thread: Fuel filter housing leak any suggestions?
    Regular Member Toe-side's Avatar
    Dec 2011
    Northumberland
    Default Fuel filter housing leak any suggestions?
    I have a leak or constant weep from the top of my fuel filter housing. There was a slight weep previously but since I changed my filter it has got worse. I think there is some damage or distortion to the housing as I was very careful putting it back together and have it as tight as I can get the lock ring.
    I could not identify any problems with the filter assembly when I took it to bits. I was expecting a damaged seal or similar.
    Has any one had any similar issues or had to replace the filter housing?
    Cdti 150hp 2007
    Northampton
    Engine : A20DTH
    Mileage : 88000
    They are a pain in the A R S * to put back together. Your local dealer will have the proper tool to do it so might be worth asking them to sort it. I will never attempt to do one again after the last time I tried
    Dec 2011
    Northumberland
    So its just an assembly issue rather than a new housing. Thanks, I will get it checked out. I did not realise there was a special tool required and I am un-impressed with the price of the housing replacement cost ...........£110 on Ebay! So fingers crossed it my assembly technique.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Toe-side View Post
    Yes I would go with the assembly issue first
  1. Oil filter housing leak.
    By Nez in forum Engine & Drivetrain
    Last Post: 12th December 2012, 16:31
  2. 1.9cdti fuel filter housing leak ?
    By john1 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 18:41
  3. Fuel leak from filter housing
    By tom_nw in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2010, 23:27
  4. fuel filter housing
    By daddyjay in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 13:19
vectra c fuel filter leak
leakage in fuel housing vauxhall costs
vectra c 1.9 cdti fuel filter housing leaking
