Thread: 2005 Vectra 1.9 CDTi 150 injector seal
    Sep 2009
    Plymouth
    Default 2005 Vectra 1.9 CDTi 150 injector seal
    Hi all,
    I read a guide in here about replacing a seal on the injector which I followed. Really straight forward, however it's leaking again.
    I spent a while cleaning the injector and the seat as best I could but now it's leaking again I'm thinking the seat is probably damaged due to the amount of pressure leaking?
    The sounds terrible some days but other days not so bad.
    If I was to take out and clean and replace the copper washer again how can I make sure of a really good seal?
    Am I going to find it needs either a special repair or replacement head...?
    Cheers all,
    Matt
    Regular Member Mopar Man's Avatar
    herts
    As long as you have torqued the injector retaining bolt down and has not sealed. You will have to get the injector seat recut, easy job if you got the tool.
    Sep 2009
    Plymouth
    It was torqued down yeah and was ok for a little bit....
    I take it this tool would be vauxhall specialist or dealer....?
    herts
    Any decent garage should have one.
  1. Rubber seal needed for dab Aerial on a 2005 vectra elite.
    By hibbski in forum Bodywork & Interior
    Last Post: 11th June 2012, 19:40
  2. Injector seal gone??
    By Governor in forum Diesel Engine related
    Last Post: 4th December 2011, 15:13
  3. Injector Seal Replacement
    By siz1 in forum Engine & Drivetrain
    Last Post: 24th March 2011, 10:53
  4. 2005 Vectra 1900 CDTi 150 Injector Leaking
    By MXB74 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 23:17
  5. Possible Injector seal maybe????
    Last Post: 12th November 2010, 20:53
vectra 1.9 cdti injector seals
vectra c 1.9 cdti injector seal
vectra cdti 150 injector gasket
vectra cdti injector seals
Vauxhall vectra cdti 120 sealing injector
vauxhall vectra injector seals
leaking injector vauxhall 1.9
2005 vauxhall vectra c injector seal
injector washers vectra 1.9 cdti
2008 vauxhall vectra injector sealant
replace injectors in a 1.9 vauxhall vectra
vectra cdti injector seal tool
how to change injector seal 1.9 vectra
vauxhall 1.9 150 injector seals
vectra 1.9 cdti injector leaking
how to change injector seal vectra 19cdti
injector seals vauxhall vectra 1.9 cdti
how to change injector seals on a vectra c
opel vectra cdti injector seals
injector seals vectra c 1.9 cdti
vectra 1.9 cdti injector seals leaking
injector for 2005 vectra
injector seals on vectra cdti
vauxhall vectra diesel injector seals
seals gone on injector vectra 1.9cdti
