Results 1 to 3 of 3
Thread: Help with spring rates please.
    Jun 2011
    Kent
    Default Help with spring rates please.
    Hi Guys and Gals;
    Mods, please can you leave this post here as it is general regarding spring rates rather than modifying, thanks
    I'm looking to replace my springs as one has snapped (on a 2007 2.8 V6 Turbo) and I can't find many listed to fit.
    I had a look at the sticker inside the door shut on mine and there are 4 weights given so not too sure which to use.
    From top to bottom, they're as follows:-
    2080 kg
    3680 kg
    1-1120 kg
    2-0985 kg
    I'm guessing the first is the overall kerb weight, the second is maximum laden and are the other 2 the axle weights, 1 being front and 2 being the rear?
    So, can I use a spring rate for front axle of upto 1000kg or should I go for the over 1000kg rated spring?
    I guess 60kg is a fair bit but I don't want it to sit too low or too high at the front if I opt for one or the other.
    Is there a specialist supplier who can help with actual weights and spring rates and recommend and supply them?
    Cheers, Kevin
    Jun 2011
    Kent
    Does nobody know what these weights mean?
    I can't imagine I'm the first to replace my springs
    Jun 2011
    Kent
  1. VM Mates Rates
    By spennny in forum The 'Off Topic' room
    Last Post: 17th November 2010, 10:29
  2. Rates Q
    By aerodynamic18 in forum The 'Off Topic' room
    Last Post: 11th March 2010, 11:46
  3. MOT failure rates
    By Morephun in forum The 'Off Topic' room
    Last Post: 14th January 2010, 20:01
  4. Interest rates down 1.5% - enough?
    By MalcGSI in forum The 'Off Topic' room
    Last Post: 8th November 2008, 21:56
  5. billing day rates
    By shillbag in forum General Chat
    Last Post: 4th July 2006, 08:32
