Thread: Washer jet hose location + small how-to
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Default Washer jet hose location + small how-to
    Hi guys, wondering if any of you could point out where I am supposed to route the headlight washer hoses on the inside of the bumper (facelift model).
    __________________________________________________ _____________
    Finally took the plunge and started hacking my bumper apart to get the washer jets installed .
    Took everyones advice and drilled loads of small holes (using a 2mm bit) inside the markings on the back of the bumper about 2.5mm inside the line.
    Attachment 52501
    Then with double sided sticky tape (nomorenails) stuck the rear part of the washer jets to the bumper location.
    Moved round to the front side of the bumper and using my high speed die-grinder and a ¼’ router flush trimming bit (above) routed out the remaining plastic following the profile of the washer jet and ended up with this
    That was tense....... had to be sooooo carefull not to catch the inner jet part/nozzle with the router bit, so if I ever had to do it again I would probably remove the nozzle head to be on the safe side.
    Well now its all put together and sitting in the lounge as it was too dark to put it back on the car, plus I've got to install the new washer reservoir and gubbings then can have some fun getting it to work
    All in all took me about 3 hours to get to this stage, just thought I could throw some ideas for some of the other folk who were considering doing the same. Just need to figure out how to rout the jet piping and hopfully all will be well and good.
    Hope it helps
    Damo
    Slough
    90 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    nice work Damo . ive got all the bits to do mine , need to get on with it , maybe today ( as got some helpers coming over ) the bumper on mine is going to be sprayed after the holes are cut , as well as the end caps for the washers . khalid
    the vectra has gone , but not far away so ill still see it form time to time
    Regular Member davidlewis24's Avatar
    bridgend / wales
    How much did all the bits cost mate ? I've got the holes cut out and the painted covers but need the rest ?
    Year : 55
    Mileage : 92,000
    Quote Originally Posted by happypostie View Post
    nice work Damo . I've got all the bits to do mine , need to get on with it , maybe today ( as got some helpers coming over ) the bumper on mine is going to be sprayed after the holes are cut , as well as the end caps for the washers . khalid
    Cheers Khalid,
    Did think to myself at one point "What am I doing to a perfectly good bumper, cutting holes in it lol"
    Would have loved to get mine sprayed as I've noticed some of the lacquer is coming off in places due to stone chips and the usual sand blast it gets in the winter and the rattle can sprays are no where near similar match to the paint work (as you can see with the covers)
    But it will suffice for now, just got to try figure out why they are not working....... Have set all the parameters to "Present" but when going into the test function all is says is "Off" (and I did have my headlights switched on).
    Hope its not the £3 ebay Saab washer pump that's on the fritz or might need to get some Tech2 work done at some point
    Damo
    Year : 55
    Mileage : 92,000
    Quote Originally Posted by davidlewis24 View Post
    Off the top of my head mate I can't quite remember but went off the guidelines from here (can't remember which thread it was)
    13183116 - NOZZLE,HEADLAMP WASH,OUTER,RH X 1= £17.85
    13183117 - NOZZLE,HEADLAMP WASH,OUTER,LH X 1 = £17.90
    13183124 - HEADLAMP WASHER HEAD RETAINING CLIP RH X 1 = £2.44
    13183125 - HEADLAMP WASHER HEAD RETAINING CLIP LH X 1 = £ 2.43
    13208121 - COVER, HEADLAMP WASHER NOZZLE, R/H PRIMER X 1= £11.45
    13208137 - COVER, HEADLAMP WASHER NOZZLE , L/H PRIMER X 1= £11.45
    13183120 - HEADLAMP WASHER HOSE ASSY X 1= £13.75
    90508709 - PUMP,RESERVOIR,HEADLAMP WASHER X 1= £61.50
    9186040 - Reservoir, assy. Headlight X 1= £27.60
    90347698 - FILTER,HEADLAMP WASHER PUMP X 1= £2.80
    90053056 - GASKET,PUMP TO RESERVOIR, X 1= £2.46
    24438885 - RELAY,HEADLAMP WASHER X 1= £2.65
    Rattle can of VX spray paint + lacquer = £7
    I was quite fortunate that I already had the RELAY already in place in the UEC (Under bonnet fuse box) and the extra plug taped to the washer pump for the Headlamp washer pump
    Sorry I cant be more exact with regards to prices, but hope it helps
    Damo
    bridgend / wales
    Thanks mate its a great help
    Year : 55
    Mileage : 92,000
    Finally got it sorted in the end........
    Think it was a bad connection on the headlight washer pump (didn't push the connector on hard enough)
    So thats one less thing to do. Now to start saving and sourcing the level sensors/brackets + lights/wiring and look into going the whole hog
    Final out come:-
    [ame]http://youtu.be/usiE8x13TdY[/ame]
    Its really not that difficult to do just be patient and try not to rush anything, as they say "Measure 10 times, cut once!!!"
    Good luck
    Damo
  1. Washer sensor pin location
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2012, 02:08
  2. Heads-up V6 CDTI split hose location
    By hebblemarine in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2011, 07:00
  3. headlight washer hose
    By i5aces in forum Styling
    Last Post: 2nd February 2011, 12:16
  4. Washer jet Hose
    By Dazzy2006 in forum Bodywork & Interior
    Last Post: 28th December 2010, 21:38
  5. 8mtr Silverline washer hose
    By Lump in forum General items for sale
    Last Post: 29th March 2009, 16:30
vectra c facelift washer pump location
