Results 1 to 10 of 16
Thread: Just to confirm................
    May 2011
    Livingston
    Default Just to confirm................
    Which feeds are required to have lights/bulbs running with and at the same time as the interior lights, for example when i open the car with the fob........
    I know most importantly i need the switched negative, i assume the other is just a 12v feed, preferrably a permanent 12v??
    is the right?
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    What's your plans?
    If it interior light it's the grey wire of that loom, if it's dash it's the yellow/grey.
    21 Post(s)
    Mileage : 110k
    What's your plans?
    May 2011
    Livingston
    was thinking about leds in the fogs and possibly wiring the sidelights the same, which would bring them on when i unlock the car??
    so do i need 2 feeds - a perm 12v and the switched negative??
    May 2011
    Livingston
    or do i need the three feeds - just like the interior light??
    21 Post(s)
    Mileage : 110k
    If that's your plans just any yellow grey wire from the dash, there's the cig lighter light and a few others to feed from... And any earth.
    If you look on my profile and the visitors message I did what your thinking.
    May 2011
    Livingston
    hhmmmm weird cause i tried that - but it didn't work.....?
    how did you do it then? maybe i should feed mine from the interior light as i know that definitely works
    what do u think?
    21 Post(s)
    Mileage : 110k
    It depends, grey/yellow if wanting DRLs.
    Interior light if just with fob, as to have DRLs with this feed you'd have to keep interior ligh on... Did you have the LEDs polarity right when you tried them?
    May 2011
    Livingston
    was thinking just more so they would come on with the fob, rather than DRL's... i may chnage my side lights, run them off fuse 10 so they are on all the time, but for now, i want to concentrate on getting leds in the fogs so they will come on with the fob...... Does that mean i should do it off the interior light then?
    If so which 2 feeds?
    thanks for ur replies mate
    21 Post(s)
    Mileage : 110k
    For interior light feed it's the white/brown.
    http://www.vectra-c.com/forum/showpo...8&postcount=25
    I'd do the dash feed tho to a switch if you didn't want DRLs, just incase you change your mind. Best of both then with the yellow/grey dash feed
  1. Can someone confirm this please
    By wayne10244 in forum Engine & Drivetrain
    Last Post: 29th April 2012, 19:20
  2. just to confirm ?
    By Tayla in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2010, 19:50
  3. can someone please confirm
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2010, 19:39
  4. Can someone confirm that.........
    By Messenger in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2009, 13:53
  5. I know I'm right, just confirm for me..
    By AndrewTi in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2007, 11:53
