Thread: Signum centre rear seat won't fold down.
    Mar 2012
    Cheshire
    Default Signum centre rear seat won't fold down.
    Hi
    I've got a problem with my 2003 Signum. I've discovered that the centre rear seat won't fold down flat, it just seems to be stuck in the upright position and I can't shift it.
    Has anyone had this problem before or has anyone any ideas what I can do to shift it, I'm a DJ and the car's useless to me if I can't use the full luggage area.
    Thanks in advance for any advice
    Quote Originally Posted by markthedoc View Post
    Hi
    i take it your lifting the handle on the back of the seat , if that isnt working then the cable from the handle has either come loose or broken
    Mar 2012
    Cheshire
    Quote Originally Posted by marktaylor View Post
    Hi thanks for the reply. Yeah both the handle on the back and front don't do anything.
    If you mean the front handle by the bottom of the front seat on the tunnel , all that does is let's you turn over the base of the seat it won't do
    Anything for the back of the seat
    Best thing to do is remove the middle
    Seat and have a look at it
    It's held in by 2 bolts and 2 nuts
    2 bolts are at the sides between the middle and outer seats and the 2 nuts are athe back of the middle seat , they may be covered by bits of foam and carpet
    Sent from my iPhone using My thumb
    Mar 2012
    Cheshire
    Thanks for the reply Mark.
    It was the back of the seat that was the problem, I took it apart and you were right, the cable had come loose, so I connected that up and all is working fine again.
    Good to hear its all sorted mark
  1. Signum Rear Seat Won't Fold Flat
    By Astra_Alex in forum Bodywork & Interior
    Last Post: 24th August 2012, 21:11
  2. Signum centre rear seat will not flip
    By Bomber G in forum Bodywork & Interior
    Last Post: 19th June 2012, 12:21
  3. Centre Rear "Seat" on a Signum
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2009, 23:33
  4. Signum - Who can sit on the rear centre seat?
    By Trundlebus in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2007, 12:02
  5. Help! Can't fold rear seat back up!
    By ferrisio in forum Bodywork & Interior
    Last Post: 2nd July 2006, 17:25
