Thread: How to find error codes?
    Sep 2009
    essex
    Default How to find error codes?
    Hi all,
    My 2.2 dti has decided to go into limp mode from when started, even with the ignition on it has the spanner light on.
    I am having trouble finding the way to get the error codes I tried the accelerator brake thing but didnt work, could anyone tell me their way of doing it incase im reading it wrong.
    thanks
    Regular Member BYGino's Avatar
    Jun 2011
    Lanarkshire, Scotland
    Doesn't work with all models. Best just get (or borrow) a fault code reader, one of the cheap eBay ones will do the job just fine.
    Sep 2009
    essex
    ok, thanks.
    Is just annoying, is there anywhere you can get them off the shelf at a decent price?
    thanks
    Jun 2011
    Not sure ,mate, I think all the "off the shelf ones are pretty expensive by comparison.
    You've got a couple of options.
    1) A handheld reader that just spits out the error code.
    2) A USB reader that you can plug into a laptop.
    3) Bluetooth reader that you can use with your mobile/PC.
    Option 2 is the cheapest, 1 is the easiest.
    If you were closer, I'd do it for you. I've got a cheap USB ELM327 from eBay and use it with Movi Pro on my MacBook Air and it works a treat. There was a thread on here recently talking about code readers, I'll see if I can find it.
    EDIT Here it is
    Jun 2011
    DP-
    New Member erni3wi5e's Avatar
    Feb 2012
    Ipswich
    Check ur inbox.
    Sep 2009
    essex
    Thanks fellas,
    I'm going to go through the common stuff, EGR, boost sensor, hopefully will have a lucky break. Then will order in a reader and see what comes up.
    Will update..
    Sep 2009
    essex
    Thanks fellas,
    Will update..
    Sep 2009
    essex
    A quick update,
    I cleaned up the EGR valve then had a look inside the chamber where it resiculates the gases and it was unbelievably clogged up covering almost what I think is the boost sensor, on the top of the air intake manifold, so I scraped all the gunk out and gave it a good clean up... And all is well, with a massive improvement on pick up on acceleration, it idles better when cold and no limp mode.
    I had the diagnostics put on it and all fault codes go to boost pressure sensors and EGR valve.
    All except one an ecu malfunction, would that be because of it going into limp mode?
    Thanks for your help guys
    Sep 2009
    essex
    A quick update,
  1. (error codes)
    By tomo610 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th June 2012, 20:07
  2. error codes
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2012, 20:33
  3. Error codes
    By Ziggy in forum Engine & Drivetrain
    Last Post: 17th February 2012, 14:26
  4. 3 error codes
    By Hydravox in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:14
  5. Need Some Help...Vec-B Error Codes
    By Vaux-Man-G in forum General Chat
    Last Post: 9th April 2009, 08:56
