Thread: Black Sludge?
    Mar 2012
    Cambs
    Default Black Sludge?
    Hi guys, not been on here for ages and even had to reregister as forgot all log in details.
    Hope this is in the right section, if not feel free to move it.
    Ok here goes.
    Vectra CDTi 150 on 06 with a DTUK box. Been fine for a long time now some 35k miles. car has done 75k now. the other day while having a play with a mondingo i noticed a lot of greyish smoke on power but once lifted nothing and nothing at constant throttled or light power., but smoke on hard throttle.
    Checked the comp and saw a temp of 95' so nothing too hot. when i stoped i checked the the oil and its fine but their is a black sludge in the header. No loss of water.
    VX tech thinks it could be either the EGR cooler, EGR valve, Turbo or head gasket.
    Im propper stumped. Dont want to be spending loads on things that might be faulty?
    Please any ideas, it runs fine but have noticed that even when hot there is little or no presure in the cooling system?
    A
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Do they have egr cooler?
    What about oil cooler?
    Probably worth getting cooling system pressure done.
    Aswell as getting sniff test.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Mar 2012
    Cambs
    yes the do have EGR cooler, mine sits on the front of the head above the turbo, some are on the side of the block above the gear box
    Oil cooler would cause a mayo type of sludge as oil and water mixing.
    Pressure check would show that theee is a loss of some sort but not show where
    Sniff test would only show exhaust gas in the cooland but not pin point to where its coming from.
    Thanks for you thoughts
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Pressure test the coolant system and a compression test on the engine would eliminate most of the things you've mentioned
    Regular Member Mopar Man's Avatar
    herts
    You can bye pass the oil cooler by connecting the two hoses up, then cleaning your header tank out. And see if the sludge reappears. The car will be fine like this, until you get another, if needed.
    Remove the h tank and i find washing powder works well.
    Mar 2012
    Cambs
    Quote Originally Posted by Mopar Man View Post
    ok i'll have a look at that but i do drive it hard, will it not over heat the oil?
    But as i say its more like soot then oil in the water.
    Mar 2012
    Cambs
    thanks.
    will try that if i can get a tool to do the compresssion test. guess will have to remove the glow plugs?
  1. cappicino sludge top off oil cap on dipstick and black coolant, old corsa
    By Jow20 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th May 2011, 20:36
  2. sludge in oil filler cap!!!!!!!!!!!
    By TimTay in forum Engine & Drivetrain
    Last Post: 27th December 2010, 15:23
  3. Is this sludge?
    By sharpo in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2009, 06:15
  4. White Sludge
    Last Post: 18th April 2009, 23:01
  5. Engine Oil Sludge
    By MrBond in forum Engine & Drivetrain
    Last Post: 18th February 2008, 11:11
