Thread: The same engine in fiat, but multijet.
    Regular Member smiley-sri's Avatar
    Jul 2009
    Tamworth
    Default The same engine in fiat, but multijet.
    Im taking about the 1.9 CDTI 8v. Now in the vectra there 120 bhp standard, the same unit in the fiat punto multijet is 130bhp standard and the only difference i can find are the different injectors. The have 4 holes to spay the fuel mix into the cylinder more evenly.
    Now most of the Fiats rolling roaded standard are coming up at 140+ bhp and can be tuned with a map and decat to see near enough 200bhp.
    Do you think the injectors will work in the vectra out the fiat as the heads the same but is the programming on the Ecu different?
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Programmed differently i'd imagine, as Vaux use different ECU's to Fiat. Correct me if i'm wrong though
    Mar 2012
    Cambs
    if you change the injectoer they will need to be Tech2'd
    Jun 2011
    Herts
    the progaramme may be different but the computer language and the ratios used will be the same for both engines. Sounds like an interesting and worth while mod- dependind on cost obviously.
    I've heard of 8v 120 vecs being mapper to 170ish so the injectors must make a huge difference if the get you another 30 horses!!!
    Jul 2009
    Tamworth
    Any body else have any thoughts on this?
  1. **** Fiat !!!
    By spoons in forum Comedy & Humour
    Last Post: 16th March 2011, 09:59
  2. 1.9 cdti a fiat engine ?
    By cranny 27 in forum Diesel Engine related
    Last Post: 21st November 2009, 10:39
  3. Fiat engine?
    By mcints77 in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2009, 11:06
  4. fiat engine ??
    By nigec in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2009, 23:40
  5. Fiat Panda
    By MLC in forum General Chat
    Last Post: 3rd October 2006, 03:42
